need quick answer
need quick answer
Ok, I've been breezing through the FAQ and looking at custom Cold air intakes and what not, can someone give me the dimensions of the Throttle body on a 92 MX-3 GS (V6 K8)? Is it 2.5"? Also, can I fit the VAF into the bottom of an K&N air filter without using a coupler? I'm trying to compile a list of items I need to buy to put it all together so any advice would be awesome!
Re: need quick answer
What would I do about the vac hose that goes to the FPR?
read the guide i posted. link is under the pic.
oh do you mean the nipple that goes to the egr that is on the filter box of the stock intake? i cut a hole in a coupler and hot glued a connector (nipple) in place. that needs to have vacuum with open throttle but no vacuum at idle so id put it as close to the filter as possible.
I put that vac hose on the second connector right below the TB since it fit almost perfectly for now. (gonna change it a bit down the road though).
Thanks for all the tips! BTW I know the setup may look funky but it worked out quite well and rests about 1" above the the bottom plastic cover under the car, i know this may not be a technical "cold air intake" but my other accordian tube thing was shredded and held together with duct tape and electric tape haha.
