By Passing air con
mrswany2009
By Passing air con
Post by mrswany2009 »
hope i have selected the correct fourm area.
My mx3 is being converted into a track car, will be racing in the summer of 2011.
i could do with some advise on bypassing the aircon, i want to know if i could simply cap the ends of the pipes and or remove them from the rad and cap them without it impacting any other system.
i might have a good general knowlege of cars, but aircon remains a mistery to me.
thanks
Ryan
Re: By Passing air con
Post by Ryan »
Just remove everything related.
Don't eat the refrigerant.
mrswany2009
thanks for that,
i was hesitent to make a sandwich with the green stuff.
you have confirmed that it wont do my inereds any could.
would it still need to be blanked of at the rad.
perhaps i need to have a better look at the other end.
Ryan
Post by Ryan »
Drain the lines, remove the compressor, condenser, etc... I'm not sure where the evaporator sits, but I can only imagine it would be a PITA.
mrswany2009
thanks, at the moment thats the least of its worries.
the cam belt has gone on it so should do that, but the engine smokes at high revs (black) so will change engine with other one. but aircon is now all out thanks.
Newfie_dan
Post by Newfie_dan »
get the refrigerant profesionallty removed, if its the old stuff that stuff can kill you literally, it amazes me how some people take a/c refigerant so nonchalantly. Its serious stuff, the older refrigerants are highly toxic and can seriously injure you if not outright kill you if you breathe that stuff in. The new stuff is not as toxic but it is still to be taken seriously, don't mess with it and don't take a chance with your safety or others, get it removed right. After that its simply remove all the components, hoses, evap, condenser etc.
mrswany2009
thanks well to late as its all out, luckly there was nothing left, and could not have worked anyway. but thanks for the warning. i was lucky i never new the stuff was that bad.
anyway lifting the engine out nearly killed me anyway, what a lump
RX8SE3P
Post by RX8SE3P »
What if it's stinking hot when you race? :lol:
1995 Eunos 30x KLZE
mrswany2009
i would rather the exrtra speed and try and sweat out some of my fat, than put it back in lol
mrswany2009 wrote:i would rather the exrtra speed and try and sweat out some of my fat, than put it back in lol
Install a roof vent to blast air on you. I would carefully remove the entire system then sell it here. It must be worth $2-300 at least to someone who wants to chill in the summer.. If if't the older R12 the refridgerant destroys the ozone layer as well. 1 chlorine molecule in the refridgerant can destroy 100,000 ozone molecules. Bad stuff. (do I need spell check) lol
