megasquirt
megasquirt
I'm trying to turbo my 93 gs se with a klze and i was wondering if you anyone can help me with a wiring diagram for straight into the harness not tap into the ecu???
- JWMX3
Re: megasquirt
have you tried here http://www.MSefi.com
- fowljesse
Re: megasquirt
I tapped the ECU, and may bypass it.
- mx3autozam
Re: megasquirt
This is how mine is setup, thanks to Nd4spdse who did it originally. It is running as full standalone and connectoed to the pins on the back of the yellow connector for the ecu. the ecu pins have all been cut and don't power the ecu at all. Its pretty much the ecu case so its sorta like a plug and play setup.
93 Mazda MX3 KLZE Turbo
Re: megasquirt
have you tried to install it????
- Ryan
Re: megasquirt
Why not just take the yellow female plugs out entirely, and scrap the case?
Re: megasquirt
wow!!! that is really nice. i just finished most of my wiring, but i think i may do it over to mimic this setup. very clean!!! i have a 96 but when i started wiring, i found that the 4th plug in my ecu can be totally eliminated if you have a wideband. the 4th plug is only for o2s and egr
klze swap, wisco 8.5 comp pistons, pauter rods, act stage 3 clutch, lightened flywheel, UR racing pulley, flex-o-lite oil cooler, 2.5" custom exhaust with high flow cat, B&M short throw shifter, S&R cross drilled rotors, , B&G lowering springs, maxxim 17" gun metal rims, modded nissan injectors, walbro 255 lph fuel pump, areomotive afpr, msd 6a , magasquirt v3, and turboed
