Hey guys, I have been looking at installing a set of the Spyder HID Projectors. Everything I have read about them sounds cool and they seem to be of good quality. So I will spend the $235 on ebay to get a set of the HID ones. My question here is one of lens longevity. Could those of you guys that are running these (or even just the non HID projectors) post up how long you have had them and how much (if any) fogging of the lenses you are seeing. I did do a bit of searching around this forum and got a lot of good info on the projectors, but the lens fogging is really only something that time will reveal if there is a issue with it. Much appreciated
Tunes67
I've had them on for about 3 months now and I haven't had any problem at all. Other people have noted some minor issues that may bring quality control into question so I'd say there's at least a chance that some were made with a less than perfect seal on the lens.
2004 Honda RC51 --- Lost forever to some theavin' bastard My Worklog My feedback thread Never attribute to malice that which can be adequately explained by stupidity.
I've had them on for about 6 months now and I haven't had any problem at all.
I'm using Xenon 12K in it......
Never run faster than your angel can fly!........ My angel has NOS My worklog || Brazil => http://www.mx3zone.com" onclick="window.open(this.href);return false;
The wires on mine weren't soldered or crimped, they were just joined with heat shrink and they came apart. A real fire issue if I had them connected. Also I've read complaints about the main connector and I've had a problem with it so I recommend you replace it with stock MX3 connector. Apart from that the look and fit is perfect.
Thanks guys.. just want to get rid of the dreaded "Yellow Lens" syndrome that the stock lights always end up with. If these lenses are better.. that would be a great bonus not to have to buff the lights 2-3 times a year
Tunes67
I had wire problems on mine, but a simple rewiring solved that. I've been having alignment issues since installing my mazdaspeed bumper (that has alignment issues as well, TOTALLY did not fit compared to stock, still have more work to go on it) but the headlights have been pointing way too low, and if I adjust them to point at the right height the hood won't close. Front end was never in an accident, so I hafta play with it more when I can take the bumper off. Theyre not amazing quality. They move around a little, and they don't really have the best design as far as function or aesthetics, but they are still better than stock plastic ones. The lens and lights themselves seem to be of decent quality.
Well if you are worried about lense longevity why not out some of the 3m clear plastic over the lense, it will add some strength and prevent oxidation and damage to the lense cover. If you run HIDs then it may be an issue with heat but I personally hate the whole HID trend as its annoying as hell having someone wih them up your tail end on the road or coming straight at you on a highway. I think that the stock projectors cast tons of light needed by the average driver. But to each their own.
