klze ditsy
klze ditsy
ok so i have a 7 nipple ditsy and the stcok external coil came with it from the car it came out of can i wire this into my gs i searched msd seems to be the only option that i can find
it be nice to us it i paid for it
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: klze ditsy
it depends how the coil is wired. If it's just pos, neg and center HT lead then it's no different than using a Blaster coil.
Post a pic of the coil. I've never seen what it looks like.
Re: klze ditsy
for sure ill grab it when im out at the shop next, it looks like the ons on the 4 banger but im not sure if its the exact same ill look when i get it
- mx3autozam
Re: klze ditsy
Ever seen the people who run external coils and HEI modules with a msd power tower in there disty cap. Its the same setup as that but you do not need to install the power tower in the cap because the ze disty has the 7th nipple. You will need the connector to run the cam sensor inside the disty. Look on proberalk for how to's on it. Its been done many times before. Its one of the best things I have done to my car.
93 Mazda MX3 KLZE Turbo
Re: klze ditsy
![Image](http://img172.imageshack.us/img172/9098/heicoilze.jpg)
Re: klze ditsy
got the coil last night the coil
![Image](http://img3.imageshack.us/img3/2667/coil3.jpg)
![Image](http://img44.imageshack.us/img44/2888/coil2.jpg)
![Image](http://img194.imageshack.us/img194/6069/coilw.jpg)
sorry for the bad pic had to use my blackberry
Re: klze ditsy
kk so im guessen on the coil that ones power the others grnd but itsthe only thing it could be. so the other two conetions could that be the ingnitor like the HEI mod that i have already done? just a thought? ![Shrug :shrug:](./images/smilies/shrug.gif)
Re: klze ditsy
anyone else have one???
