ecu
ecu
ok so if i get a mx6 v6 ecu and kl02 vaf can i run it on my mx3 de
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: ecu
KL02 or KL03 ECU with KL02 VAF combo should work just fine. It'll make the engine still think it's in an mx6. If you have two coolan temp sensors, your fans will just stay on all the time unless you wire in the extra sensor.
I'm actually going to be running that very setup on my mx3 except the engine (DE) is from a 93 Probe GT.
There are a few posts on here regarding the ECU VAF combos.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
Re: ecu
Your motor is a DE
The Mx-6 uses a DE
The Mx-6 ECU and VAF are for a DE
Should be obvious enough.
The Mx-6 uses a DE
Re: ecu
ok so i was looking thro the latest post and i found that you could use a k8 ecua and kl02 vaf and it would work has anyone tried this
Re: ecu
Ayeee, wrong post.
'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
'93 Ford Probe GT - a few mods... 10.24 @ 139.5 mph [20 psi] - 545 whp, 490 wtq @ 21psi
1997 Ford Probe GTS (Hybrid) - RWD Conversion - Build Thread
Re: ecu
Many; that's why we say you can do it. It's not ideal, but it works.mccabe wrote:ok so i was looking thro the latest post and i found that you could use a k8 ecua and kl02 vaf and it would work has anyone tried this
