quick question
quick question
ok so i was offered to get my exsahst done for free i just hav e to supply the muffler cat and piping my question is thet if it is done and i wont to swap a kl into my 92 gs willit still fit or will it have to redone???
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
- solo_ryder
Re: quick question
Yes it will work. Get some 2.25" piping and a hiflow cat+resonator+muffler and you can use that setup on a KLZE/KLDE.
Re: quick question
if you plan on using stock exhaust mani's and y pipe then if you swap for a KL and get some headers there will be a need for modification. the 7 pipe on the aftermarket headers go about 8" farther to the rear then stock.
NEED PARTS INSTALLED? PM ME!
Re: quick question
yra im not buying headers but but from there downs all new. Im going to buy the headers off ebay tho when i do the swap?
- tehbrookzorz
Re: quick question
Where do I get my exhaust done for free!?
*Insures car and drives to Calgary.*
Cody
Re: quick question
my buddys doin it at the schools shop i go to
Re: quick question
Ebay headers, $160 bucks delivered and they work great. I used a couple 1/4" exhaust spacers on the crossover pipe as the pipe contacts the oil pan. See motorsportpartz on ebay.
