Short shift for cheap
Has anybody tryed this?<BR>I don't really understand the explanation. <A HREF="http://www.mx3gsr.freeservers.com/shortshift.htm" TARGET=_blank>http://www.mx3gsr.freeservers.com/shortshift.htm</A>
Jonathan Michaud
93 Red RS
93 Red RS
Re: Short shift for cheap
sounds too risky, i'll pay for the pacesetter
I did it I love it tight shift! I have another for sale got my friend to weld it he is a welder at the Zoo so you know it strong
- mrspanky79
I have done it too and have had no problems. I went to the junkyard and got a shifter for $10. Marked out my measurements and put the shifter in a vise upside down and hit the bottom ontill the ball comes lose,dosent take much. Clean up the bur and slide the ball to the spot you want it then give it a quick braze so the ball dosent move. Done no need to cut and do all this welding. And if you want you can cut some of the top to make it a shorter stick. Hope that helps
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>...I have another for sale ...[/QB]<HR></BLOCKQUOTE><P>how much?
Jonathan Michaud
93 Red RS
93 Red RS
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mrspanky79:<BR><STRONG>I have done it too and have had no problems. I went to the junkyard and got a shifter for $10. Marked out my measurements and put the shifter in a vise upside down and hit the bottom ontill the ball comes lose,dosent take much. Clean up the bur and slide the ball to the spot you want it then give it a quick braze so the ball dosent move. Done no need to cut and do all this welding. And if you want you can cut some of the top to make it a shorter stick. Hope that helps </STRONG><HR></BLOCKQUOTE><P>Was the new shifter from a mx-3. Can you use the one from a 323, protege or escort?
Jonathan Michaud
93 Red RS
93 Red RS
- mrspanky79
i got it from a mx-3
99 vitara 4x4
99 vitara 4x4
[img]shrug.gif"%20border="0[/img] $50cnd + shipping
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by white fish:<BR><STRONG>
Jonathan Michaud
93 Red RS
93 Red RS
Oh and one more thing, will it fit my RS (not the same tranny)?
Jonathan Michaud
93 Red RS
93 Red RS
I dont know if it will fit in a RS I dont see why not its 36% shorter and my friend thats a welder at the Zoo cut it below the ball welded in .9 on an Inch of rod in and grinded it smooth and I have cut the top about an Inch and added a couple of extra threads the weld is strong as hell
Well I'm still not convinced. I know the pacesetter shifter fit both RS and GS but I would like to be sure that this one will fit my car before I buy it.
Jonathan Michaud
93 Red RS
93 Red RS
And one more thing, did you made it for your 2.5l v6 or the 1.8l v6?<p>[ January 29, 2002: Message edited by: Brainless ]
Jonathan Michaud
93 Red RS
93 Red RS
the shift for ALL proteges, 2nd gen Escorts, MX-3s are all the same, and will interchange.
-93 MR2
#129 E-stock
#129 E-stock
i will buy one if you can ship it to south carolina in the USA let me know desparks@mindspring.com
SLOW AND THE PISSED OFF<BR>(Take that Fast and the Furious)
