What mods are you planning over the winter season?
- solo_ryder
As the title states guys, anyone got some cool plans from now till spring?
- mx-3_4evr
Re: What mods are you planning over the winter season?
Right now I'm finishing the engine. For winter I want to finish my interior in suede/vinyl & do the rear disc brake conversion. Spring get the car painted. Will see if I can make it happen!
- fowljesse
Yeah!
Whiteline swaybar with Wytbishop's endlinks, corner balance, long tube headers, fiberglass hatch, Lexan side & rear windows, Wider rims & tires, paint, slim visors
(haven't kept any for myself), EGR delete hopefully, finish soundproofing, if I don't get the SRD reproduction suspension stuff, I'll make it myself, Mfactory helical LSD *Fingers crossed*, knock the dents out of the sides of the stock GS, make the turn signal hole into a ram air duct (I put in Civic headlights with turn signal in them), cover the bottom of the car for smooth airflow & and downforce, maybe put in KL31 intake cams... That's all I can think of.
- cjthor
1. carbon fiber hatch install
2. aluminum intake (as long as JWMotorsports finds time to finish it!)
3. redo my battery/spare tire well
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- fowljesse
With Lexan!cjthor wrote:1. carbon fiber hatch install
Collecting parts and figuring out if it is possible to turbocharge a V6 without removing the air conditioner and power steering...
- marcdh
1. Get Megasquirt fully wired and in control (then dyno with vaf in the way and without)
2. Possibly get some coilovers
3. Trying to source polycarbonate rear window maker/wait for Jesse to show the DIY way
4. Install slim visors at last
5. Finish molding in guage pods to pillar
View Worklog
View Worklog
- boosted_bullet
alot on my plate....
paint n body work,
rims and bodykit,
94+ dash conversion
rear disc conversion
atx to mtx swap
kl-de swap
yeah and i havent gotten started yet...
paint n body work,
rims and bodykit,
94+ dash conversion
atx to mtx swap
kl-de swap
chicks dig the rice!
-bullet
-bullet
colinf004
complete KL-DE rebuild again......
some body work too doors & hatch
OMG where do I start???
I have amassed about $1000 worth of parts and all I need is some new polyurethane Wytbushings to reassemble my entire suspension. I have new rear spindles, hubs, Lateral Links, Brake lines and E-Brake cables. I have a rear sub-frame and trailing arms as well as front LCA's, transverse member and engine crossmember ready for powder coating. I bought all new factory hardware to pin it all together. Once the bushings are in the entire suspension of the car will be as new.
After that, I have a tranny that I'm going to attempt to rebuild myself. I will then install it with a new clutch, slave cylinder and Corksport stainless clutch line. I think i will also have the tranny case hottanked and paint it so it looks like new. I may do this first if the bushings wind up waiting till spring.
Then if all goes well I will have the car ready for paint in the spring. I have a nearly new rear bumper to replace my cracked one and I have arranged for a new JDM bumper and lip from Corksport to be picked up in spring. I also have a line on a set of used JDM foglights...$80...score!
Once the paint is done, I have only to stick on my Smoked Slim Visors and I will have one very cherry 93' GS SE. I hope to be able to get all that done by June of 09'.
So I got the package of rear end parts I bought from this guy in Ont. yesterday and the front TTL's, the non-adjustable ones, are not even MX-3 parts!!! I've very annoyed. I'm hoping I can sell them and use the money to subsidize a pair of new ones.
He hasn't returned my email asking WTF??? I hate it when people are not straight up.
When I was home this past weekend I managed to squeeze by and pick them up, so they're in my hands. I wanted to bring them with me to ship out but I bag was maxed for weight for the plane. I'll have them sent out your way sometime in the next few weeks.fowljesse wrote:if I don't get the SRD reproduction suspension stuff, I'll make it myself
For myself, I've got a few things planned
- Traction Bars
- Wytbishops End Links
- CF hatch. Still need to get the MazdaSpeed lexan hatch window and i'm putting on a new wing.
- Motor rebuild
I still need to pull the motor and get the rebuilt, but I'm waiting until the new year to see how work goes before buying the remaining, more expensive parts. Works has been going really well, so I'm been using that to pay off debts and save some cash. And then you've got xmas around the corner. I'd also like to get my rims redone since they've got some nasty uneven-pavement-rash on them. But the motor it going to be a very expensive and time consuming project...i can't wait
hgallegos915
Doing my clutch with an expensive name brand.
New tires.
Fix my power steering, oil pan.
Get thios baby ready for the summer.
And to paint it .
New tires.
And to paint it .
-hec
- solo_ryder
WHITE OR SILVER HECTOR
Not sorry for caps
Not sorry for caps
- Megasquirt
- Learn how to use/tune usig megasquirt
- Re-install everything I had powder coated (Intake, Valve Covers, All brackets and everything else I could pull off ect...)
