so ive noticed something...therees 3 sensors or somethin on the transmission...2 are exactly the same just in different spot and im trying to figure out what they do cause the wires ripped out of it when i was pullin the engine (couldnt get the connectors seperated and was a little pissed so i said F it ill fix it later; now im paying for it) so anyways theres 2 green wires coming from both sensors and there seems to be no telling either green wire apart...does anyone know what these do? and how bad i need them haha thanks...
ill post pictures if need them, once i get them...
transmission solenoids? sensors?
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
Re: transmission solenoids? sensors?
Is it auto or manual?
If its manual - then it could be speedo sensor, reverse light switch and neutral safety switch. There might be a ground strap there too.
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
yea its a manual...two of them are identical and the 3rd one is like part of the block it looks like...but both wires are the same and pulled straight out of the plug and straight off of the sensor so even if there was telling them apart theres still no way of knowing where they go...where could i buy one of these?
