KLZE RAN QUICK FIRST TIME ON TRACK
- stereoking15
so, after figuring out how to launch the car with minimal wheel spin (1200-1500 rpm) acting like coming from a stop sign i ran tons of 14.1 q's at 98-99 and fastest of an 14.084 at 99 and 2.194 60' time. tires were falken rt 615's 235/40/17 aired to bout 26-28 lbs. still open diff
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
- solo_ryder
Re: KLZE RAN QUICK FIRST TIME ON TRACK
NICE! those are great times!
wow I'm impressed - wish I had been there to see it! dude we've got to meet up!!!
damn nice times. 235 tires? damn you couldnt turn with those
93 mx-3 w/ Curved Neck klze
- stereoking15
i have 17x7 sport max 618 rims with a offset of 38 or 42mm with an 1/8 inch spacer on all 4. rears would have cleared but just as a precaution used them, fronts are very close no rubbing lock to lock even during racing conditions.
- TREVO123
Try runnin slicks, should put u in the 13s
You deleted the VRIS, whats up with that?
- stereoking15
by deleting vris the intake acts like a single plane manifold therefore increasing velocity in higher rpm but lose a little bit of torquein the lower rpm thats a shame when at the strip when u cant launch a car like a honda at 9500 rpm just to turn the tires a little. i think when i do a dyno and also by my quarter mile times running a stock intake that my mods have been effective even though others said it doesnt work that way or u cant do that. that means they dont understand or havent tried.
The pioneer spirit is alive and well. Keep us posted.
- fowljesse
My guess is that it just narrows the powerband, and causes less restriction, so your peak power will be a little more. Just like how Leo run individual Hyabusa TBs,for the same purpose.
- mx3autozam
with a stock airbox, that its impressive!
93 Mazda MX3 KLZE Turbo
- DimaK
.......i think i want to put my ze in the precidia now.......
- Dragyn Vyrus
damn thats nice!
hopefully i can get mine running that good or better once i get the eprom chip!
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
