What plugs in this sensor
Barambambase
Post by Barambambase »
hello guys, i need some help figuring out what is this plug, I have no engine light on dash, but the mx won't pass smog test without a plug there. I have circled the area, there are 2 plugs in that area.
f--- RACING IN STRAIGH LINES, whats the point?
solo_ryder
Re: What plugs in this sensor
Post by solo_ryder »
No pic?
Barambambase
trying to attach hehehehe, that was quicker than me figuring out how to attach pic
solo_ryder
Hahah, get the http:// address and put it between the IMG brackets when you press the IMG button
Barambambase
http://s66.photobucket.com/albums/h256/ ... k8plug.jpg" onclick="window.open(this.href);return false; there is the link
solo_ryder
Can you get a closer pic? That is either the coolant temp sensor or the crank angle sensor. Dont think your car will run without the crank angle sensor though
Barambambase
yes is something related to coolant, since is real close to that colant cap. is coming from the neck of the tube where cap is on. I have no engine light on. Where does that plugs to on the other side??
i can't get any closer pics, car is 40 mins away, i've been looking at peoples engine bays, but no close ups of that area, or picture links don't work. :(
Kirk95gs
Post by Kirk95gs »
I have this pic of when I did my swap. It might be to close, its of the k8.
http://i153.photobucket.com/albums/s204 ... 020073.jpg
Barambambase
yeah thats the one!
thanks a lot guys for quick response, where does the other end goes??
you think pepboys will have it, or just go straight to NAPA?
Kirk95gs
Post by Kirk95gs »
I dont really understand what you meanwhere does the other end go.. if you fallow the harness over from from behind the intake manifold to where the coolant sensor is. there is only a couple plugs. one is the knock sensor that goes between the heads. one is the crank angle sensor that fallows the oil dip stick down. One is coolant temp sensor. there might be a ground, I can't remember.
Barambambase
i think it has to be the coolant one. what i mean is if i buy the plug that goes to that coolant temp sensor, plug it in, where does the other end of plug go?
solo_ryder
That is the knock sensor.
Barambambase
I will go take pictures in a few days.
Raven95150
Post by Raven95150 »
Here is your pic:
BTW, when using Photobucket or other photo hosting sites, they provide you with the IMG code, just copy and paste it.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
Barambambase
thanks a lot man, i will try get a closer up picture of it, since that one is too general.
