[FS] 93 RS Engine + 5spd Trans and misc parts
				Blazianenigma
Im going RWD so I have all these for sale....
4cyc Engine 190xxx miles (full drop with all wiring etc)
5spd trans (full trans...slave cylinder, clutch, shifter...etc)
Im asking 350 for the whole drivetrain...dropped out.
Basically you pop the hood and everything you see related to the engine and trans is yours
GS Cluster
RS Cluster
RS Gas Tank
Misc Interior Trim
Evo 5 Front Bumper
GS Cluster
RS Cluster
RS Gas Tank
Misc Interior Trim
Evo 5 Front Bumper
1993 MX-3 (Converting in Oct)
2004 MS6 (Repairing)
1982 Limited Edition Me (.04Hp)
- ElectricEnergy
Re: [FS] 93 RS Engine + 5spd Trans and misc parts
Hold on, your switching cars... or converting your mx-3 to RWD? If your doing the conversion definitely keep a good work log. That will be an awesome project!
David
							David
				Blazianenigma
ditching the whole fwd system and everything with it and going RWD 13b if I can find a decent priced one (on project budget and major timeframe)ElectricEnergy wrote:Hold on, your switching cars... or converting your mx-3 to RWD? If your doing the conversion definitely keep a good work log. That will be an awesome project!
David
So selling off everythin that I no longer need from the GS
- 1992blazeredgs
I may need another 1.6 sohc, if i cant get mine running correctly. How much for just the long block? I should know here in a few weeks if I will need it.
Nate
							Nate
Looking for another Red GS.
				Blazianenigma
Whats your offer on it?1992blazeredgs wrote:I may need another 1.6 sohc, if i cant get mine running correctly. How much for just the long block? I should know here in a few weeks if I will need it.
Nate
Personally I would rather get rid of the whole thing...
rather than having pieces left over here and there.
Its not like Im gonna be needing then ya know.
- 1992blazeredgs
I'll call around and see what the going rate is, then I will make you an offer.  Then maybe we can negotiate from there.  Sound good?
Nate
							Nate
				Blazianenigma
Cool.1992blazeredgs wrote:I'll call around and see what the going rate is, then I will make you an offer. Then maybe we can negotiate from there. Sound good?
Nate
No problem
				Blazianenigma
bump
				Blazianenigma
bump...
is the 1.6 tranny the same as the K8? if so, im intrested in tranny and everything included
							92' GS KLDE, Cosmo Racing UDP, CAI, AWR Motor mounts solid, Pheno spacers . interior gutted, MTX Swap, unorthodox racing flywheel/ 4 paddle clutch. short shifter, SRD bushings, brembo cross-drilled rotors, corksport racings red stainless steel lines. megan escort springs, zx2 sturts, whiteline rear sway bar, rear strut bar.
No the 1.8 and 1.6 have different transmissions.
And i do need a tranny, do you ship to canada? Around how much would it be?
what color is the Evo 5 Bumper?  Any cracks, etc?  I'm interested.  Let me know
							'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
				Blazianenigma
bump
