[FS] 93 RS Engine + 5spd Trans and misc parts
Blazianenigma
Post by Blazianenigma »
Im going RWD so I have all these for sale....
4cyc Engine 190xxx miles (full drop with all wiring etc)
5spd trans (full trans...slave cylinder, clutch, shifter...etc)
Im asking 350 for the whole drivetrain...dropped out.
Basically you pop the hood and everything you see related to the engine and trans is yours
GS Cluster
RS Cluster
RS Gas Tank
Misc Interior Trim
Evo 5 Front Bumper
1993 MX-3 (Converting in Oct)
2004 MS6 (Repairing)
1982 Limited Edition Me (.04Hp)
ElectricEnergy
Re: [FS] 93 RS Engine + 5spd Trans and misc parts
Post by ElectricEnergy »
Hold on, your switching cars... or converting your mx-3 to RWD? If your doing the conversion definitely keep a good work log. That will be an awesome project!
David
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
Blazianenigma
ElectricEnergy wrote:Hold on, your switching cars... or converting your mx-3 to RWD? If your doing the conversion definitely keep a good work log. That will be an awesome project!
David
ditching the whole fwd system and everything with it and going RWD 13b if I can find a decent priced one (on project budget and major timeframe)
So selling off everythin that I no longer need from the GS
1992blazeredgs
Post by 1992blazeredgs »
I may need another 1.6 sohc, if i cant get mine running correctly. How much for just the long block? I should know here in a few weeks if I will need it.
Nate
Looking for another Red GS.
Blazianenigma
1992blazeredgs wrote:I may need another 1.6 sohc, if i cant get mine running correctly. How much for just the long block? I should know here in a few weeks if I will need it.
Nate
Whats your offer on it?
Personally I would rather get rid of the whole thing...
rather than having pieces left over here and there.
Its not like Im gonna be needing then ya know.
1992blazeredgs
I'll call around and see what the going rate is, then I will make you an offer. Then maybe we can negotiate from there. Sound good?
Nate
Blazianenigma
1992blazeredgs wrote:I'll call around and see what the going rate is, then I will make you an offer. Then maybe we can negotiate from there. Sound good?
Nate
Cool.
No problem
Blazianenigma
bump
Blazianenigma
bump... :crying:
studboy13
Post by studboy13 »
is the 1.6 tranny the same as the K8? if so, im intrested in tranny and everything included
92' GS KLDE, Cosmo Racing UDP, CAI, AWR Motor mounts solid, Pheno spacers . interior gutted, MTX Swap, unorthodox racing flywheel/ 4 paddle clutch. short shifter, SRD bushings, brembo cross-drilled rotors, corksport racings red stainless steel lines. megan escort springs, zx2 sturts, whiteline rear sway bar, rear strut bar.
Vanished
Post by Vanished »
No the 1.8 and 1.6 have different transmissions.
And i do need a tranny, do you ship to canada? Around how much would it be?
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
mazdags94
Post by mazdags94 »
what color is the Evo 5 Bumper? Any cracks, etc? I'm interested. Let me know
Blazianenigma
bump
