Turbo Manifold
Turbo Manifold
I have not really seen much in here or the FAQ about what Turbo Manifolds with fit the DOHC 1.6 and was wondering if the Miata 1.6 one would fit right
http://cgi.ebay.com/ebaymotors/MAZDA-1- ... otohosting
94 Mazda MX-3
Mods - none yet
Mods - none yet
just for general info
i bought one
i had to do a little "aftermarketing" to the aftermarket manifold
as far as i could tell it would either be cutting some of the shroud on the hood or taking out the primary fan
your better off getting it custom made for cheaper
i bought one
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
![Image](http://img.photobucket.com/albums/v454/glytcher/mx3%20stuff/ZOOMZOOM-1-1.jpg)
yeah depending on the turbo you use, you would need to cut the hood, and not in a spot to put a scoop
"and no it a spot to put a scoop"
e-ricor
e-ricor
FYI - The turbo exhaust manifold from a 88 or 89 Mazda 323 GTX is a direct bolt-on for the DOHC 1.6 (i.e., the B6DE). Moreover, the same exhaust and turbo gaskets fit quite nicely.
My local Mazda dealership can still get them and you can also get them from Corksport... Or you can have the manifold made.
make note though
you can only use the vj and vf series turbos
i decided to just use this cheapo manifold as a base and make mine based off a t3/t4
PM me if you'd like a custom manifold. They range in price from $320USD to about what ever you can dream up! See my cardomain page (link at bottom in my sig. We have pictures of a few manifolds on there.
- cyclonekid78
If the maita turbo manny fits just cut it off at the flange and flip it, then reweld. So simple.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
