Hi guys, i have a J-spec Straight Neck KL-ZE (KL-31)
Below is a list of bearings (LINK) but there is one or two which seem smilar, to be sure is there anyone here who knows exactly which ones i need and what their part number is on the list?
I have tryed contacting them but they mention something called "10 over" or "20 over" what is that? Also what "Pin" do i have 20mm or 21mm?
Confused...........
http://www.flatlander-ipp.co.uk/toga/to ... azda.shtml
Which TOGA Bearings, KL-ZE experts please click....list 4U
- PATDIESEL
The 10 ro 20 over is the bore at which a machine shop will sand out of the cylinder wall when rebuilding a motor. You should go 10 over if possible as it is less material removed. 20 over is the max Mazda reccomends you bore the motor. This is usually called "over bore".
The "pin" they are refering to is the wrist pin I guess. The standard KL uses 20mm and the Millinea use 21mm. This is the pin that holds the piston to the piston rod.
