What Clutch?
What Clutch?
I just got a BP in Nov. with a new aftermarket OEM Replacement clutch..
The artards @ the shop didn't resurface the flywheel i'm sure and i got a bit of slip like 2 days later.
I drove it for 800Km nice and easy trying to rework the face of the clutch.It did..... I've been driving it for about 8000K now and i'm getting slip again..
A BP is only like 50more hp then a B6...I'm going turbo so if this is happening i'm getting an ACT street clutch...
Q: Would the initial slip have screwed the clutch right from the start?..Or did my "world is my race-track" driving do this.
Q: Could the clutch just be glazed over and need tobe sanded ?
I'm running a F-Series trans on a BP so i have a B6 Flywheel and clutch
Q: Is the G-series clutch Larger AKA more gripping power.
Q: Is an ACT Street Clutch and pressure plate going to hold the power of a 7-psi BP?
Thx in advance to any and all repliers
- Limegreen mx-3
Yes noticable differece. over the f-series. I am also running a f-series with a catch. 90-93 miata flywheel miata ACT Xtreme pressure plate. stock mx-3 clutch disc. can't complain got a 12.8@110.
Yes it will hold the power. BUT why settle for a ACT STREET. go for the ACT Xtreme. worth it in the long run. ONCE u go boost u will want more.
I thought of that but i'm not the kind of person to just buy and hope it fits...
Flyinmiata provided me with the information as to the flywheel weight difference...
ACT lists 2x 4-pad and 2x 6-pad clutches....but both are 22spline....just 200 and 224mm difference.? Should not then both clutches fit the F-Series AND G-Series Input spline?
So...
Flying miata lightweight 1.8 flywheel + 1.8 ACT Xtreme pressure-plate + 1.6 clutch + bearings + tool
= 429+386+102+46+4 =
$967US = $1137.69CAD +tax+shipping+border = Aprx $1500..
So...
Cy:
If you are looking for another option (and a Canadian one at that), perhaps http://www.bullyclutch.com/indexen.html would do the trick. I am going with a 'stage 4' six puck configuration for my B6DE turbo project. Should give me some flex if I tweak things up beyond 8 psi...
Should have it installed in about two weeks... provided life doesn't offer any surprizes
Regards.
Regards.
Try http://www.clutchnet.com or http://www.specclutch.com
For around $800US you can get a 12lb aluminum flywheel, 3-puck sprung hub metallic disc, and a 2300lb pressure plate from Clutchnet. This setup is rated at 600lb/ft. torque capacity.
My first setup was a ACT simi-metallic street disc, ACT heavy duty pressure plate, Pro-LX 22ish lb flywheel. At 13psi on a large Garrett GT30R I TOASTED the clutch! It was rated at around 280lb/ft. torque.
My last setup was the Clutchnet 3-puck sprung hub metallic disc, ACT 2100lb pressure plate, and both the SPEC 9lb flywheel and Pro-LX 22ish lb flywheel. Rated at 485lb/ft. torque. At 26psi on a large Garrett GT30R with a conservative timing map I was slipping this clutch .
My current setup is a Clutchnet 3-puck sprung hub metallic disc, Clutchnet dual diaphram 2300lb pressure plate, & a SPEC 9lb flywheel. Doesn't slip anymore!!!
My next setup I'm looking to SPEC for a custom twin disc setup.
Increasing the clutch O.D. will increase torque capacity. Also, making the clutches surface area SMALLER will dramatically increase torque capacity. The reason is it applies more clamp force to a given point.
A handy referance tool for calculating clutch capacity....http://www.zoomperformance.com/torque_calculator.html
P.S.
My setup is based off the 92 Pro-LX drive line. The 323 clutch disc and pressure plate are the same...I think the flywheels are also. The NA 2nd Gen RX-7's use the same clutch disc as well but the locating dowel pins on the flywheel are slightly different making the pressure plate not a direct swap.![Wink :wink:](./images/smilies/icon_wink.gif)
P.S.
- Limegreen mx-3
[quote="Cy"]I thought of that but i'm not the kind of person to just buy and hope it fits.....[/quote]
Thought of what !!??
F-Series is a 20 spline count
G-series id a 22 spline count
BOTH 1.6 miata and 1.8 miata have a 22 spline count just 1.6 is a 200mm
and 1.8 is the 224mm difference.
[quote="Cy"] Flying miata lightweight 1.8 flywheel + 1.8 ACT Xtreme pressure-plate + 1.6 clutch + bearings + tool [quote]
u got it all wrong i have the 1.6 miata stock flywheel 1.6 miata ACT Xtreme pressure-plate and the 20spline stock mx-3 clutch disc reason why it fits with the f-series trans.
- Franko
I have a Bully Clutch and it is BAD a--. Call them up, they are really awesome guys. Im sure that the person you talk to on the phone will be the guy actually making your clutch for you and is not just some salesperson.
I called them a couple of months ago because mine had some marks in the pressure plate. They were really nice and said that its normal. I told them the clutch wasent slipping and he said "Ohh god Its not going to slip on you. If you want it redone you can send it to us but it will definately be fine."
I like that confidence that he has about their product. I would recomend a bully for anyone. I have a stage 3 six puck.
![Image](http://i17.tinypic.com/30idc09.jpg)
ok so i'm getting a tad kuffufled about all the info
My hopes are to get a 1.8L flywheel and pressure plate and use a 1.6L clutch disc..
Is this possible? or do you have to go 1.6 from the flywheel out...?
As far as bully clutch, I've never been a fan of unspring clutches...Because I do 99.9% street/autoX driving and i like a smooth engaging clutch..
Also.
Which flywheel are you running Frank? again i do alot of city driving with some steep hills so a 9lb is probably a little to touchy...12lb sounds great...still being like 15lbs's lighter then stock...
Again Thx to all repliers
Also.
- Franko
My clutch is sprung..
![Image](http://i9.tinypic.com/2uym5pz.jpg)
See?
The engagement is really smooth. Its just a little different way you drive it is all. Its a pretty short distance from not engaged and then engaged but when you get used to it its perfect. This is hands down the best clutch ive ever had.
And I still have the stock flywheel..
See?
- Franko
Bully Clutch 613-748-1515
Just call these guys up and tell them what flywheel and stuff youre going to be using and how much power you plan to make and he will recomend a clutch setup for you. They are really really cool guys. I dont remember my part # off hand. Its best to call them and tell them what you have anyway.
