remote mounted turbos sts
Has anyone seen the sts remote mounted turbos by sts what is your opinion of this setup.
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
- XxantwawnxX
Apparently alot of domestic guys (camaros i think) use this set up. As i hear it they say its all the rage and love it.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
their universal kit is almost 3 grand and doesn't come with much... is it really worth 3 grand?
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
I could build you a nice GT "R" series ball bearing turbo kit for $3000
Do some research before making claims like that. A properly designed remote turbo kit is very efficient, and not laggy. Dont know where you pulled that from.
Its pointless for a small displacement motor, but in cases where hood space is limited and exhaust routing is difficult, they are an excellent way to boost.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- BuGS
See I have always said this would be a great way to do a setup with a V6, instead of having to do all the engine bay modifications...rebel2k4 wrote:Do some research before making claims like that. A properly designed remote turbo kit is very efficient, and not laggy. Dont know where you pulled that from.
