Hoodzy's How To: Cold Air Intake
I hope that someone see's these questions soon... here it goes:
In this picture, i have put 2 letters.
I really want to know what are these tubes for.
If someone could help me please
The A tube, is it a leftover oil tube ?
And the B tube ? mine is disconnected ... it is only with some "cork" in it
HELP !
HELP !
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
- vasilaar
Hoodzy...
Are you still using that airfilter that you took a picture of? or have your put a real filter in yet?
just wondering, because it looks like a filter that i got off of ebay a while back with one of my intake kits.
if it is the same (i'm not saying it is... it's just dangerously similar) its a total peice of crap.
that intake doesn't filter anything at all.
in fact the filter part of it is all for show. ALL (or at least about 99%) or the air coming in comes through the screen at the end, which as i'm sure u can imagine doesn't have the same screening properties as the filter.
i ran that filter for a while, and sucked up SOOO much Dust, the inside of the intake pipe was caked, and even my throttle body and intake manifold were showing some serious fatigue.
that s--- can't possibly be good for the motor, so i changed it out and cleaned the hell out of it.
just pointing this out because it happened to me, i hope that you have it under control.
good luck.
good luck.
Drive it like you stole it.
- Hoodzy
well as long as its close to the ground it should be fine but always have the sucking up water problem.. if ur not gonna have fresh air flowing near it then u'll want it as far away from the engine as possible such as where i've put it behind the headlight
1995 Creek Mica Blue GS
- Hoodzy
confirmed its a 3.5 to 2.5 inch coupler from the VAF to piping.. picked one up off ebay.. my old one wasn't high quality silicone so it was gettin all deformed
- Tunes67
For the most part that is correct.. its not enough of an increase by itself to make a noticeable difference. Now if you do a good CAI and do headers and better flowing exhaust system.. then you should see some noticeable gains.. remember.. a engine is really only a fancy air pump.. you can only take in as much as you can put out and vice versa.and I was wanting to put a cold air intake on it. But from what i've gathered from this thread is that it won't really give much HP increase? Is that correct?
Tunes67
