all right good to hear have u turned it on. if u can replace the plugs cap&rotor on the BP and a oil change and fliter fram sucks don't use that.Gottagofaster wrote:allright i went to the yard today I got the wireing harness ecu and rail from the bp. all went well now i'm putting it in i'l post some pics of the project pretty soon.
Bp question.....
- Limegreen mx-3
Gottagofaster
well my day started out going to the yard getting my stuff(8am) 3 hours later back at my house(11am) with the new harness ecu, and rail..went and rented engine lift(12am) lifted old engine out(12:30am) disconnected tranny from old motor and changed flywheel and clutch(serious tight bolts on the bp)(1:30pm) put the flywheel and clutch on the bp(2:15pm). pulled old wiring harness and ecu(3:30pm) well anyway you get the idea right now it's 4:30 am and I just finished everything and i got in to start her up.....and the starter wasn't engaging so i was just like ok fine i'l just roll start it....but when i walked to the front of the car there was a giant trail of fuel....So i decided i was done for hte night.....and where can i find the firing order for my disty? or sprk wire goes into which slot on my disty?
- Shades
Since you now have both fuel rails (EGT and Pro), could you visually let us know what the differences are. Maybe a few pictures, please and thank you.
For those guru's out there... will an EGT wireharness work with the Protege fuel rail?
"Do it ONCE, do it RIGHT!"
Gottagofaster
well I can tell you the difference. on the ford bp the return is on the right and the sending line/in line(some reason i cna't htink of the name) is on the left.
I have a quick question about them though can i use the injectors off of the ford on the pro fuel rail? or do i need to use the pro injectors? i'm wondering because i got my motor in and while i was starting it up. i noticed i had a serious gas leak...so i looked at it and it looks like the injectors arn't getting a good seal? not sure if thats because of the age or incompatability
- Limegreen mx-3
u can use the egt injecters on the mazda fuel rail but each injecters come with 2 seals. top and bottom. total of 8 seals bottom seals are differnt from the top seals.
Gottagofaster
