Too much fuel management????
- cjthor
Ok so Im running an apexi super afc, 320cc injectors, and a rising rate fuel pressure regulator. I think the acf and RRFPR are trying to fight eachother and my car wont go rich. Should I delete the RRFPR with a regular regulator???
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
From my experience, i'd say they are fighting eachother.
Try eliminating the RRFPR and see what happens.
If you have the bigger injectors and presumably bigger fuel pump, i'd say thats enough fuel already.
IMO, The RRFPR causes fuel pressure the SAFC isnt acounting for.
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
- Franko
You definately got too much going on there. You have so much changed on the car that you would be better off just going standalone. Get a haltech e6k or something. For the love of god do not get a megasquirt. They are the shits to tune, Id trust an ipod to run the engine more than I would trust a MS..
If you got an e6x they are fairly cheap these days and will work wonders, You can eliminate the rrfpr and the safc and sell them to offset the cost of a standalone. I remember being worried about going standalone in my car since its my only car and I drive it every day.. but man.. it was actually the best thing I have ever bought for the car. The car works so good and is so reliable I drive it every day, rain or shine.
The benifits of being able to precisely ajust your fuel and timing needs.. Your car will be so much better I guarantee it. Youll wonder how you even survived without it.
- cjthor
Not ready for standalone. Sooo delete the RRFPR and just use the stock regulator/???Franko wrote:You definately got too much going on there. You have so much changed on the car that you would be better off just going standalone. Get a haltech e6k or something. For the love of god do not get a megasquirt. They are the shits to tune, Id trust an ipod to run the engine more than I would trust a MS..
Jarid Perry
- XxantwawnxX
i had no prior tuning or standalone experience and i found MS (MSnS) to be very simple and easy to tune. I guess it just down to the person doing it.Franko wrote:Y For the love of god do not get a megasquirt. They are the shits to tune, Id trust an ipod to run the engine more than I would trust a MS..
Not trying to sell a product thats not even mine, just giving another side of the story.
EDIT: keep in mind i had the base map pre made for me. So i did not have to start from scratch.
- Franko
Ive used a few standalones.. aem, haltech, crome and ms.. By far .. the ms software is the worst of them all. Its not even in milliseconds like every other one is.. Its in percentages.. how dumb. Personally.. I just hate it, Maybe its just me.
Anyway.. Why arent you ready to go standalone? From the sounds of what you got done to your car you are.. Why not?
- XxantwawnxX
MSnS is a standalone. Most people just dont treat it as one. Its doing everything perfect for me atm i dont need anything else. I could get rid of my stock ECU and just use MSnS for everyhthing but i decided to keep the stock for some things it does fine..like IAC and Fuelpump and such(plus it was extra work and i was lazy *cough cough*). Maybe its cause ive never used any other standalone but MSnS seemed simple enough fo rme to learn, just had to read up on the site a bit.
- cjthor
I dunno....its just id be the first to do this on a dohc four cyl and im not really sure.....does anyone have a manual for an e6k i can look thru?Franko wrote:Ive used a few standalones.. aem, haltech, crome and ms.. By far .. the ms software is the worst of them all. Its not even in milliseconds like every other one is.. Its in percentages.. how dumb. Personally.. I just hate it, Maybe its just me.
Jarid Perry
all you need to map ANY ecu beyond computer experience is a gooooot EGT an AFR Gauge and something to adjust the throttle slowly and hold it @ an rpm...like your foot...---EGT + AFR mounted RIGHT after the turbo or right after the CATbox on the stock DOHC..Then rpm match with the resolution of the tuning software and adjust fuel mix to desired AFR and acceptable EGTs...
THIS IS THE REASON I LOVE THE GREDDY EMANAGE SOFTWARE.. you set an AFR and it will MAKE the map... then you just tune for power on a dyno...
The biggest bastage of the whole lot is wiring everything up...
- XxantwawnxX
Cy wrote:The biggest bastage of the whole lot is wiring everything up...
so the e manage is like a slightly better safc? after reading what you posted on the e manage, i read up on it. sounds like a very good piggyback but for the money the megasquirt does a lot more. either way, both the megasquirt and the emanage functionality is very user friendly according to their description. +
having full timing and fuel adjustablility has enormous benefits. with timing and fuel adjustability you can run a much more efficient, and safe tune that WILL have more power. you will be able to make more power and run more boost due to the fact that you can adjust timing seperately from fuel control where as the safc does not allow you to do such. oit will also keep from having the "black rear bumper" that typically comes with piggyback systems, larger injectors and boost. better economy, more power potential, better drivability and safer tune, all come with having an ems.
if you spent all that in your engine bay, its only fair that you have proper tuning tools to get the most, power, economy and safest tune. im sure most of us would rather see you with proper fuel and timing management since it is the safest and best route to making the most out of what you have. ...and what you have is very nice and a ems would compliment your setup well. not to mention, for the price of the megasquirt piggybacks are obsolete.
- Franko
E6K Manualcjthor wrote:I dunno....its just id be the first to do this on a dohc four cyl and im not really sure.....does anyone have a manual for an e6k i can look thru?Franko wrote:Ive used a few standalones.. aem, haltech, crome and ms.. By far .. the ms software is the worst of them all. Its not even in milliseconds like every other one is.. Its in percentages.. how dumb. Personally.. I just hate it, Maybe its just me.
E6K Wiring
Its pretty straight foward stuff. Im positive you can do it man.
- BuGS
If you car is going to be a DD I would go for the greddy emanage Ulitimate. U can delet your AFM for a MAP, you can control Ignition and fuel, and it has the auto-tune feature. Plus you have the reliabilty of a stock ecu and stock setup. Unless you wanted to spend the BIG Bucks for the right standalone, I would really suggest with going with the best piggyback on the market.
