You're thinking of the 10.5 sec NA ZE powered PGT that I posted pics and info about last fall???Minimonster wrote:From where? and how can I find info on the car?BuGS wrote:there is that one that was running 10's... I think he had a F2t or FE3??
RacingMazda's Project MX-3 (Dyno 475whp@18psi) NEW PIC 4pg
- jschrauwen
- MechaManZero
That car is friggen sick man.
							Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
				Minimonster
Does any one know what suspension "he" was running?
							Proud builder of
455 hp Miata 10.98@125mph
MX-3 RS 25 psi 451 hp
MX-6 F2T 12.8 @ 112 mph
(Current Project) A 700 hp MX-3 now at 475 hp
- MechaManZero
Lol at the "...we was running?"Minimonster wrote:Does any one know what suspension we was running?
Sorry sounded like some ghetto slang there.
Çlark
- Josh
i know what bugs is saying. last fall there were 2 cars that pulled into the 10's last fall. and they were from Quebec, one was Daves old car. the other i dont rember, but the interior wasnt stripped out.
- BuGS
Ya, Josh hit it on the head. Dave's Car has a new owner that got it into 10's, then Some other guy I think with a KL-ZE Turbo setup ran like 10s with full interior...Josh wrote:i know what bugs is saying. last fall there were 2 cars that pulled into the 10's last fall. and they were from Quebec, one was Daves old car. the other i dont rember, but the interior wasnt stripped out.
- Limegreen mx-3
(12.4@118@18psi) 92 MX-3, KIA (BP-DE)Swap, Electromotive TEC II Standalone, 8,200 Rev Limit, Custom Intake/Exhaust Manifold, 1,000cc PTE Injectors, Custom Fuel Rail, Aeromotive FPR, 80MM Holley TB, MSD 8.5MM Wires, NGK V-Power #8, SC6262 Turbo, 3 in. DownPipe, Tial WG/BOV, 600HP PTE FMIC, 2.5IN Intercooler Piping, EQUUS/Autometer KIA G-Series Tran, Extreme ACT Clutch, Built BP in starting  process.
						- MechaManZero
nice times lol. 12 seconds would be good enough for me though. I am more about playing with the kids on the streets.
							Çlark
				projectmx
amazing job on that mx-3 guys.... wish i lived closer to racing mazda next year i'm hoping to do a turbo set up... This year i have to finish the awd and bp swap... my bottom end is really strong but the top end i've only done a p&p and valve job... how much do your bp kits run?
							ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
- Limegreen mx-3
Well the LX trans finally  gave out like that wasn't going to happen. it sucks but it will be replaced. just an update happen sat.
						- Limegreen mx-3
got the 98 kis trans looks beffier than the LX trans hopefully it can hold up to RIC 700whp goal. trans will be installed soon.
laters Limegreen MX-3
				JWMotorsports
Use a Kaaz Diff in it with Lucas 80w90 Heavy Duty Gear Oil w/ 1 bottl of Lucas Trans Fix and you might hold it...for a little while.  Also check out the post on the Pro LX box upgrade options we did not to long ago.  Yoda and I delved pretty deep into the topic.
Recommend:
-Billet Dog Gears & Shafts
-Ceramic coat the bellhousings on the inside to keep heat out of the metal
-Kaaz Mazdaspeed Protege LSD w/ full lock up option
-Integrate a front mount oil cooler and electric pump to cool trans fluid
With those mods it should take 700HP as long as your block doesn't twist the tranny case.
Also...I'd love some pics of the tranny you just broke...or the pieces them selves so I can see what failed....I'm guessing the spider gears crumbled if you still had the stock diff in it. Thank you!
							Recommend:
