I have a 1993 mazda mx-3 GS with the 2.5 probe GT engine swap. I have a corksport strutbar, tokico blue struts, eihbach ground control springs, DC headers, stainless Brullen catback, and a PRM cold air intake. I also have a nitrous setup sitting here for a rainy day. I have heard they will handle a 75 shot? I have half a motor in extra parts in my garage, mostly heads in case I need a rebuild or replacement. I plan on running a 50 shot off the bat. What can I expect out of this setup?
Is this a decent setup? How do the parts on my car rank among others available? I found them reasonably priced and bough my upgrades without really researching first. I have had 2 civics with JDM motors and I can see there are a lot less parts for these mazdas. I like a challenge and a car that hardly anyone else owns let alone even knows what it is! I just put 2 BRAND NEW axles in it, (not the re-man ones) 2 ball joints, 2 tierod ends, and a new carrier bearing for the right side halfshaft.
thanks, and glad to be a part of the forum!
(are oil leaks a common problem with these motors? if so, where should I check first, mine leaks a little bit but its hard to tell where from, before I dig into it, I was wondering if it is common and it may be easy to diagnose)
