93_mx3_gs wrote:
I found a guy, well a friend of a friend. Who has a 1994 MX-6 with a..I don't know what the hell happened to the rear, looks like 100K lbs was dropped on it or something but the back half is all beyond flat.
Anywho getting to the point. The Motor is a KL-101 = KLDE = 160 Hp right ?
The motor has 120K on it well, says the odometer. It's nt too dirty, lot of dust from sitting but the motor seems in failry good shape and I am wondering, Should I get the ECU out of this car as well ? Or because of the rear damage, do you think it may have electrically affected the ECU ?
I'm getting the motor delivered for 250.00 so I think I should jump on the motor in any case. He also has a set up pulled from some car but he said the exhaust manifolds would fit the KL-101 in the mx-3 and they are turbo manifolds. He's got everything from turbo unit down to oil like for $175.00.
Heres where the problem comes in, I unsterstand a lot of what people say about this and that but I don't want to do a stand alone or 'piggyback' or whatever in my car because i'd like for it to somewhat to pass emissions.
Also, If the ECU is fine, Will the 1994 MX-6 ECU fit directly into the 1993 MX-3's wiring system ?
Can I hook this KLDE motor up with the same ECU and run turbo on it without any modifications ? Or am I looking to spend a shat load of money ?
You have a lot of Q's which means your doin something right.
