92 gs engine light
92 gs engine light
I recently bought a 1992 gs. I have a problem with water leaking in the windshield, have the windshield to put in... just no time yet. Anyways, a few days ago it rained heavily, I vaccumed the water out. However, My check engine light has come on. I don't know if it is coincidence or not, but it came on before when the passenger floor got wet , and seemed to go off after the car dried out. Is there a code reader I should consider buying?? Do you think there is a correlation between the water and the light? I have allowed the car to dry out very well, but this time the light won't go out. When the motor is cold the light is not on. However, after a few minutes of driving it comes on and won't go off. If I restart after the motor is warm, the light immediately comes on. Is it my oxygen sensors? If so , how hard to remove and is there a reset button for the light? Thanks.
Re: 92 gs engine light
Have your EGR Valve checked. Mine did the same thing. About the moisture, if you let it dry very well, no worries. When my EGR Valve clogged-up, that darn light came on.<P>The error code you're looking for is 16. If your error code reads 16, chances are it's your EGR.
