klze intake ports
- shawno
klze intake ports
I have a klze i hope but i was wondering if anyone could send or post up pics of the difference in looks between the j spec there the square ports and the, american ports with are D shape or oval.
This is a straight neck klze:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33615
This is a curved neck klze:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... egory=6755
This is a klde:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WD1V
The klde has more oval shaped runners and has a short straight neck
This is a klde:
mxmaz wrote:also remember that there is a curved neck klde from a millenia which externally looks the exact same as a curved neck klze.
I know Gro mentioned the TB markings as a check....is there anything I can use to tell definitively what engine I really have? The engine I've got has intake manifold w/squared runners, KL31-101/KL31-1A1 heads, KL01 cams, and KL on the block. Besides the TB, what else? I thought I had things covered.
Perhaps more importantly, if it ends up being a Millenia KLDE, and the hassle/rework involved in exchanging this engine doesn't appear worth it to me and I decide to keep it (the engine itself is superclean and has already had work done on it) ....well, what position am I left in? I have a KL31 ECU, headers that fit, JE50 VAF from my K8, etc. What parts would I need to combine to get this engine to run well? If it'll run well, I might just suck it up and keep it....it'd be a different story if I was doing the work myself.
'93 MX-3 GS
check lakersfans post in this thread http://mx-3.com/phpbb2/viewtopic.php?t=41840millaj01 wrote:mxmaz wrote:also remember that there is a curved neck klde from a millenia which externally looks the exact same as a curved neck klze.Of course, I thought I had done all the proper research and taken the proper precautions in looking for marknigs when I bought my engine from Noyan. Now that I've posted pics, specs, etc., it appears I may have gotten one of these 'phantom KLZE' engines......which is really a KLDE Millenia engine. (see tail end of my KLZE swap/Pile O' Stuff post)
Gro Harlem
Using a flashlight to look inside the actual cylinders to see if the pistons are flat-topped and not dished. Dished = lower compression KLDE crap, flat = 10:1 klze stuff.millaj01 wrote:mxmaz wrote:also remember that there is a curved neck klde from a millenia which externally looks the exact same as a curved neck klze.Of course, I thought I had done all the proper research and taken the proper precautions in looking for marknigs when I bought my engine from Noyan. Now that I've posted pics, specs, etc., it appears I may have gotten one of these 'phantom KLZE' engines......which is really a KLDE Millenia engine. (see tail end of my KLZE swap/Pile O' Stuff post)
hard to really tell thru such a small sparkplug opening tho, but it is possible
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
If you can wait till tomorrow i will post a pic of the
KLZE port's
They are very square with 10mm raduis corners.
Also my cam's have KL31 stamped on them
this motor is out of a eunos 800
KLZE port's
KimmiKim
what does a "kl31" stamped on the tb mean? i bid on this engine STUPIDLY before i learned about this common mixup. the guys were nice though, they're going to pull the plugs and wires and shine a flashlight down to see the piston shape after they eat lunch. i really hope its a curved neck klze...
-Kim
1993 MX-3 GS in Raspberry Metallic
...awaiting swap...
...awaiting swap...
Those 'dishes' are actually providing clearance for the valves. Because with the ZE the piston is extremely close to the head at Top Dead Center. Which gives you the high compression numbers. The KLDE piston looks like like a bowl in the middle.shawno wrote:ok so the pic of the port is a square port and the pic of the piston has dishes i was led to belive that the klze engine had a flat piston and the klde engine had the dishes
92 GS
'Stock'...
'Stock'...
