KLZE TB
- jschrauwen
KLZE TB
Simple question here. What's the type/model# of the J-Spec TB for the KLZE engine? KL??
And for that matter, what's the VAF type/model#? KL??
lakersfan1
- jschrauwen
lakersfan, just way too helpfull todaylakersfan1 wrote:Jap spec KLZE throttle body should be a KL31 stamp on it.
Jap spec K-series engines all used JE50 VAF's. KL02 VAF's were only used on American spec KL's.
So as to be ready to install KL31 ECU, I'm going to source a JE50 VAF - would I still be OK with my KL68 TB or if a KL31 TB was available, would that be better choice/route to shoot for? Plus's and minus's of choice selection?
I'm guessing you didn't keep your K8 vaf? (which is the JE50 BTW)
lakersfan1
- jschrauwen
Unfortunately no (as he kicks himself in the a--). I left all that stuff at the place that installed the ZE. It's been near impossible to nail this guy down to track down all of those niggly things that were missed, overlooked and neglected. Besides, it's a 2.5 hour drive one way. I'm doin' the old, I shoulda, I shoulda, I shoulda dance.Nd4SpdSe wrote:I'm guessing you didn't keep your K8 vaf? (which is the JE50 BTW)
So, should I stick with the KL68 or try to source a KL31 TB. BTW, I don't seem to see any signature profiles indicating a KL68 TB, and I'm not sure I should take that as a good or a bad thing. I have seen 67mm TB and a few KL31's, but no KL68's.
- babyblueMX3
kl68 came with curve neck klze intake manifold and millenia a-spec manifolds (same TB)..I got one on my car bored to 67mm. My friend had a kl68 on his ze so that proves it
*edit..I think I got my numbers mixed up..I wanted to say kl47 ..don't know the kl68
RIP 400whp ZE-T MX-3
- jschrauwen
OK Blue, so if I read you right, you've mixed up the 68 for 47 and that you're not familiar with the KL68 and what I've got is a phantom TB, interesting.babyblueMX3 wrote:kl68 came with curve neck klze intake manifold and millenia a-spec manifolds (same TB)..I got one on my car bored to 67mm. My friend had a kl68 on his ze so that proves it
- babyblueMX3
lol you read right but you don't got a phantom TB lol..I just don't know wich one is it
- jschrauwen
OK, so I still not a 100% on the origins of a KL68 TB. No one seems to be able to nail this one down. The reason being is that I may have an opportunity at acquiring a KLZE TB which comes from a KLZE curved neck IM. Bearing in mind that I have a KL31 ECU on it's way already.
Would that TB be a KL31?
If it is a KL31, would that TB be a better choice over the KL68 and why?
What's the bore differences between the two TB's?
- babyblueMX3
hey man I wanted to post back on this but forgot..I got my friend's klze tb here and mine (millenia) his has kl68 stamp on it and mine kl47..
I also have a straight neck tb here. I'll have to check the number on it today.
so one things for sure you won't find anything bigger stock than your kl68 so keep it
- jschrauwen
Blue; OK, I think that clears things up a bit better. My KL68 TB is the J-Spec/KLZE TB from a curved neck IM. And you're saying that the KL47 TB comes from a Millennia IM? And you say that this (KL68) is the biggest OEM TB out there and that this will give me the best performance possible?
- babyblueMX3
yup..well all kl TB's are 60mm (klde,klze,millenia,whatever kl) and stock k8 is 55
- jschrauwen
If all KL TB's are 60mm, what performance differences if any would apply to a KL31 TB over a KL47 TB over a KL68 TB. 3 60mm TB's...there must be a reason/purpose why Mazda made at least 3 variations of a 60mm TB. Am I reading too much into this? It's just that when I do something I like to do it right the first time and not have to piss around with it in the future.babyblueMX3 wrote:yup..well all kl TB's are 60mm (klde,klze,millenia,whatever kl) and stock k8 is 55
