klze
MI-Archangel
klze
Post by MI-Archangel »
so got a mechanic to swap it over. But apprently i puff a bit of smock when i shift at like 7 g. my buddy who has ze in probe says its normal cuz something in engine cant keep up with something else. But any other theories the mech pulled no codes.
babyblueMX3
Re: klze
Post by babyblueMX3 »
care to explain just a little more? what ecu are you running?
RIP 400whp ZE-T MX-3
bmwm3guy
Re: klze
Post by bmwm3guy »
Wellf**k buddy, no **** you're puffing smoke at 7Gs... why are you reving it that high anyways?? the peak HP is at 5.5 last time I checked. :throwup:
lakersfan1
Re: klze
Post by lakersfan1 »
Who doesn't shift at 7,000 RPM? My great-grandmother would shift at 7,000 RPM if her car revved that high.
<small>[ August 03, 2004, 08:07 AM: Message edited by: lakersfan1 ]</small>
papa roached
Re: klze
Post by papa roached »
and the last time i checked, unless the motor has KL01 cams you make your peak at 6500 with the KL31s
Gro Harlem
Re: klze
Post by Gro Harlem »
ya, i never rev my ZE past 6500 b/c it makes ZERO POWER past there... I have revved it to 7500 once, but I didn't want to blow the head gasket or bend a valve.
DONATE TO MX-3.COM
TsiMiata
Re: klze
Post by TsiMiata »
I'll go to 7k in 1st. The jump from 1st to 2nd is a little wide. If you don't rev it that high in first when you shift it drops out of the range it makes power.
91 Eagle Talon Tsi AWD *RIP*
Re: klze
Yep, sometimes it's not how high you rev to get power, its how high you rev to make sure you stay within the power band...
<small>[ August 03, 2004, 09:26 PM: Message edited by: Nd4SpdSe ]</small>
ZEmadman
Re: klze
Post by ZEmadman »
same here, that's the only reason i drop at 6500-7000 is cuz anything less any youre out of the powerband. and if im not mistaken vris opens up all the way at like 4k? right?
babyblueMX3
Re: klze
mmm for my case it's up to 6500 and it should for everybody else too :)
PATDIESEL
Re: klze
Post by PATDIESEL »
To answer your question it is perfectly normal to puff alittle smoke when shifting at 7000. Especially for a motor that has some miles on it. However the more you shift that high the worse it will get. Wear and tear ya know.
mdavis
Re: klze
Post by mdavis »
[quote]Originally posted by bmwm3guy:
Wellf**k buddy, no **** you're puffing smoke at 7Gs... why are you reving it that high anyways?? the peak HP is at 5.5 last time I checked. ;)
<small>[ August 05, 2004, 03:34 AM: Message edited by: mdavis ]</small>
GS-R SE
Fixin's
lucky13
Re: klze
Post by lucky13 »
Does anyone have a pic on where is the crank sensor is? Also the knock sensor, please!!! :crying:
babyblueMX3
Re: klze
crank sensor is right beside the crank pulley and the knock sensor is between both heads under the manifold
