For a klze swap I need to no if a gs third month '95 is a obd1 or a obd2. How could I identify it? I did a search, but couldn't find the answer.
Thanks alot guys, Bastian
How to identify if a '95 gs is a obd1 or a obd2?
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
Re: How to identify if a '95 gs is a obd1 or a obd2?
There are several indications. One is to check how many O2 sensors you have - OBD1 has 2, OBD2 has 4.
OBD2 has the extra diagnostic connector (16 pin) under the dash, supposedly on the driver's side, but that's only conclusive if you find it
Another way is to remove the ECU and look at the connector. OBD1 has a 3 part setup, with the contacts labelled 1A-1V, 2A-2P and 3A-3Z. OBD2 is different, and I haven't got that information for certain yet but its something like 4 parts labelled 1A- 1AH, 2A-2E, 3A-3AB, 4A-4AT (This is worked out from a diagram in Chilterns, and I'm not certain its reliable - I've found errors in another diagram in the same book).
Good luck, and let us know how you get on.
<small>[ February 24, 2004, 08:06 AM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
Thanks, but I need to know it for a friend of mine, I got my own klze. One of the first ones in Europe.
Bastian
Bastian
Will this be the same on a '93 GS?
Where are the O2 sensors located?
Odds
Odds
Odds, Norway
Red `93 GS, Stock
Red `93 GS, Stock
- Zoso124
Just look under the dash and if there is a hook up for an OBDII reader. If there isn't one its OBDI.
Mike Evans
Gone:
Gone:
No worries, all '93s are OBD1. OBD2 only started during '95.Originally posted by odds1:
Odds
- Buff1110
o2 are located on the headers on the downpipe, pop the hood and look at the front header, if there is 1 o2 sensor ther the car is obd1 if there is 2 its obd2
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
