Hey guys, <BR> if you have been following my posts, you know I've been b----ing about my front motor mount being busted. I've tried to think of any way to fix the problem without buying the mount from the dealer... too expensive! I was digging around in the garage today and found some extra casters... polyurethane casters. They looked to be about the same size as the front motor mount. After some intial measuring, I decided to try and make it work. Apparently the fron motor mount is exactly 3" I.D.! After minimal trimming of the caster, and cleaning of the mount, the caster was beat into the mount and VOILA! It's amazing how much power you lose when your engine is flopping around in the engine bay every time you shift gears. I'm ready to hunt some Honda's now...<P>
![Image](http://www.wpedirect.com/images/mount1.jpg)
[img]http://www.wpe%20direct.com/images/mount2.jpg[/img]
