FS: Some B6T parts up for grabs
Aaron MacDougall
Post by Aaron MacDougall »
Have some stuff hanging around that I have no need for so here it goes
make me an offer on anything.<p>-B6t manifold with no cracks and has O2 sensor. If you wish i can also get it glass bead blasted.
-vj14 turbo with downpipe. Compressor
housing has some oil on it and turbine housing has some surface rust. Center housing has some scaling. Shaft spins freely with a little side to side play. Was told that turbo will work fine at stock PSI without a rebuild but will loose efficiency quickly once boost is turned up. Also i can get this glass bead blasted to clean it up.
-B6t intercooler...in awesome shape with just a few bent fins.
-B6t Blow off valve and most charge pipes. All charge pipes are in great shape...would be nice replacement for your B6t pipes that are not in the best shape.<p>If you want pictures of anything let me know thanks<p>[ March 20, 2003: Message edited by: Aaron MacDougall ]</p>
mx3optidrive
Re: FS: Some B6T parts up for grabs
Post by mx3optidrive »
I thought that you said that I could get first dibs on the stuff? What's up?
Shop 506-577-6708
cell 506-381-3503
email danny@jdracing.ca
Aaron MacDougall
SOLD to you :D
