Why disconnect this hose?
Re: Why disconnect this hose?
After doing some research I think I have what might be the answer. I think it's part of the PCV system since the other side goes to the other valve cover. The only reason I could find to leave it disconnected (which should never be done without at least a filter) is if excessive blowby is getting into the engine. I don't know how one would be able to tell this but from what I read apparently a catch can is a better solution then a filter or leaving it open.
- WhiteFinish
It's indeed connected between the front and rear valve cover.
Front blows, rear sucks.
The other end of the T normally leads to the airfilter box/hose.
Not sure why it needs to be connected to the airfilter side.
- clearconscience
It's sole purpose is to breathe engine fumes back into the intake for emissions
<a href="http://www.freeimagehosting.net/commerc ... phy/"><img src="http://i.imgur.com/Ebelrp3.jpg" alt="commercial photography locations"></a>
- toomanyangelz
you're right but you can advert this hose with a vent filter easily
