Can't fit drum over new brake shows on 93
Posted: November 10th, 2016, 2:34 am
Hey all,
While I'm only a weekend warrior, this is actually the first time I've ever done brake shoes.
The car is up and on jacks, the parking brake is off, I did the driver's side, and while it was difficult to get the drum cover back on, I got it.
I also noticed there appears to be no adjustment star like most online guides show.
I tried searching this forum to see if anyone has any helpful hints or guides, but alas it was to no avail.
So, the issue is that I pulled the drum cover off, cleaned everything with brake cleaner, removed all the springs, retainers, shoes, put it all back together, but I don't see any sort of adjuster. I can push the piston in fine, but can't push the shoes in enough to get the drum cover on.
Is there an adjuster anywhere on a 93 mx3 with drums?
How do I go about adjusting it for the new shoes?
It appears as though this vehicle is self-adjusting, but I still can't figure out how to reset the adjustment to allow the cover to clear the new shoes.
Thanks!
Thanks!
