CANT FIND WHERE KNOCK SENSOR PLUGS INTO HARNESS
so I found the female plug for the sensor that attaches to my engine (driver side) but I cant find the male part that comes off the wiring harness from my car
I found one connector that fits, but its for the speed sensor and doesn't get rid of the knock sensor code when I plug my computer in
does anyone have any ideas, suggestions or help for this
thanks
thanks
Re: CANT FIND WHERE KNOCK SENSOR PLUGS INTO HARNESS
Because you have a KL (you have a KL right?) they feed the knock sensor harness to the left (drivers) side of the engine.
However the harness plug is actually on the right (passenger) side of the engine. You can carefully feed the plug through to relocate it without removing anything.
However a knock sensor is a notorious sensor for failing so you may need to replace the sensor all together.
Keep in mind this is based on an OBD1 Left hand drive MX-3 GS. I never seen OBD2 so couldn't tell ya if there is a difference. I would guess maybe not.
there is no extra plugs free on the passenger side.. i dont know where to look! i would appreciate a picture?
that would be great someone might have snipped it off :\
brb. better appreciate this. it's cold outside.
Kris, is that valve cover bolt suppose to be loose. ![Smile :)](./images/smilies/icon_smile.gif)
If that was the only thing wrong with this engine... This sucker's dead, jim. er, dan
Thankyou! the plug wasent ther butt..... someone cut it out and taped over it??>...... wtf
so I ran the wires soldered them car has no codes! thanks a lot for the pic mannnn
why the heck would... sigh.... nevermind I shouldn't ask.
NO I should ask. Why would someone cut the wires off...
weight savings...SuperK wrote:why the heck would... sigh.... nevermind I shouldn't ask.
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- mitmaks
Which codes were you getting?Tfries-cc wrote:Thankyou! the plug wasent ther butt..... someone cut it out and taped over it??>...... wtf
