meandor3 - 1993 bpt gtx always updating!
summer 2015 last picture taken at automaniac 2015
obtain at feb 2010 a mx3 l4 soch 1993 with slipping clutch, completly oem no modification.
(this picture is similar of my mx3 at the begining but its aint mine)
the clutch have been change for a new one,change the gaz tank cause it was leaking from middle
and some other reparation to get the car a1 then bough new fast mags with potenza tires.
new paint from a paint shop same color also got the gs spoiler and exaust tip for the look.
2011
new paint!
hid kid 10000k 9004
apex coil spring
chrome clear light
some red interior paint to fit my carpets and mags
2011
new paint!
hid kid 10000k 9004
apex coil spring
chrome clear light
- WhiteFinish
Re: meandor3 - 1993 bpt gtx
nice !
Like the wrap around spoiler.
rust hole on the floor drive side
all the rust have been removed
anti rust paint
anti rust paint
chrome angel eye
then i wanted a black housing on them
brillant black housing
ive replace these bulb with red led
red led+blue led
h1 hid 12000k for highbeam
so bright
red led+blue led
so bright
bought a mx3 1993 special edition with klze swap top shape!
my 4 cylinder mx3 soch only have 88 hp then pass to 200 hp
its 2x faster and love the song of this motor
88 hp l4 soch 60-150 km/h
http://vid1125.photobucket.com/albums/l ... 222281.mp4
200 hp v6 doch 60-150 km/h
http://vid1125.photobucket.com/albums/l ... 247501.mp4
back to my mx3 4 cyl
my soch head after 230000 kilo
this happen to me on 3 mx-3
bough shifter linkage at the scrapward and short shift shifter from cosmo racing i dont like it its too long again...
4 inch exaust pipe rs type carbon
also found this at the scrapyard im feeling very lucky
then the fun start a new a mx3 whos running pretty bad i was not able to ride the car
an injector was leaking fuel on the intake wrong intake hose conection its supose to
be before the tb but it was plug after the vaf where the oem bov goes .
After that the car was not able to go after 3k rpm so i checked the spark plug and
1 was cracked causing mise fire then the car was not able to stay on without a booster
so i change the alternator too and everything was ok to drive it but while driving
the clutch was sipping too like my oem mx3 1993
the result if you forget your hood pin
big intercooler ready for 500 hp
black leather seat from a mx3 1993 special edition
the back
wrong motor support
the back
wrong motor support
all my mazda
here the gtr spoiler on the back
carbon cluster trim + blue indicator + indiglow cluster
swap comming soon!
swap comming soon!
- WhiteFinish
That's some spoiler
What are you swapping in?
a bpt gtx jdm
And the fun begin
the dude didnt torque the pressure plate bolt i guess...
I have remove all the grease with blue scoth towel and gotten a nice result no rust
the motor inside
the motor inside
air\fuel ratio,volt,boost gauge
the car is on the road now
i got some issues with the fmic when im reaching 10 psi+ the piping is blowing out
so i have clamp em stronger with the piping out of the car and all is ok up to 17 psi
http://vid1125.photobucket.com/albums/l ... 185206.mp4
