Measuring ABS sensor
Posted: May 19th, 2014, 5:06 pm
by WhiteFinish
Who knows if I can measure an ABS sensor when it's off the car ?
Is there a way to check if the sensor is still good?
Re: Measuring ABS sensor
Posted: May 27th, 2014, 3:54 pm
by WhiteFinish
Who could help me out ?
Posted: August 12th, 2014, 1:44 pm
by WhiteFinish
Must be somebody who knows...
Posted: August 13th, 2014, 10:15 am
by crazycanadian
The only thing you can do is a resistance check. I don't know the specs, but its not a full proof way to tell you if its still good or not. There is no full proof way to check with the sensor off the car.
Posted: August 13th, 2014, 11:01 am
by marcdh
There's a resistance range iirc around 1.5kohms. Possibly in workshop manual. Can't remember value but if they're all the same you will know they're fine. Have you pulled abs codes? I made a how to on ukmx3 years ago for that.
