So i got these axle's from a 323F.
And there are these oil groves in there, LSD maybe?
But don't think its type r cause there short.
Modified stock?
Strange Axle
Re: Strange Axle
Stock.. can't explain why but I have seen it lots...
Re: Strange Axle
Yea those are the oil cooling grooves for a jdm LSD transmission, Aaron had a set here at one time.
Re: Strange Axle
i dunno, look a this one, much longer shaft.
- WhiteFinish
Re: Strange Axle
You're comparring a mx3 with a 323.
Is the distance transmission - wheels exactly the same?
- MrMazda92
Re: Strange Axle
Well, one of those is a driver's side, and the other a passenger
It's been forever since I had both pulled at the same time, but do the shafts slide in the same depth on both sides? Come to think of it, I believe the DS is a little longer, but I may be out in left field with that one.
Re: Strange Axle
Just for info viewtopic.php?f=30&t=65792
