Vacuum line
MazdaRider
Vacuum line
Post by MazdaRider »
Can some one tell me where the vac line is I'm trying to install a vac gauge
Easy on the rs I had lots of space
With the v6 I have no idea where it is :shrug:
mitmaks
Re: Vacuum line
Post by mitmaks »
Why are you trying to install a vacuum gauge? You want to find a vacuum leak or just to have a gauge on pillar/dashboard?
Sleeper6
Re: Vacuum line
Post by Sleeper6 »
MazdaRider
Re: Vacuum line
It's just a guage what line do I "T" in to
Re: Vacuum line
T in close to the TB, any of the lines should work. Not much of an answer but then again I just told you everything you need to know. :D
MazdaRider
Re: Vacuum line
Can't really find a line off the TB an any other line I "T" in to doesn't work
Lori Carlyle
Re: Vacuum line
Post by Lori Carlyle »
Hey sleeper, do you have one of these for the Zedos9 system at all?
Owner of the UK MX3 site.
