Note: I'm not the most technically minded person.
Picture stolen from Mooneggs. (Thanks buddy)
I have that inlet manifold.
Problem is that, while it was being cleaned and painted. Some bastards walked off with the box of everything that came off it, except the fuel rails (and everything needed to attach them)
I have my spare K8 laying around.
Anyone ID it? and have some images and brains of what I can take off the k8 Inlet manifold to replace what was nicked.
Help needed
Help needed
Owner of the UK MX3 site.
Re: Help needed
Hard to say what you need from what you posted, if you could take a picture of what you have we would have a better idea what you may need.
Re: Help needed
I'm guessing you'll need:
vacuum chambers
check valve
VRIS valves
VRIS solenoids
brackets and bolts
All of this stuff will be found on the K8 manifold and can be moved over to your ZE manifold. There is probably plenty of photos too, but this link will provide the K8 manual diagrams.
Good luck.
vacuum chambers
check valve
VRIS valves
VRIS solenoids
brackets and bolts
Good luck.
