Front subframe
- WhiteFinish
Front subframe
Hi Guys,
What needs to be loosend to drop the front subframe ?
I don't want to have 90% of the bolts lose and than find out it got stuck on 1.
- MrMazda92
Re: Front subframe
Out of curiosity, what are you dropping the subframe for?
- WhiteFinish
Re: Front subframe
For a blasted and coated one
- MrMazda92
Re: Front subframe
Hell yeah!!! I've wanted to do that forever!!!
I can't help much here, but take your time lowering it, and always lower in stages so you can check for missed hoses/lines.
Re: Front subframe
While your at it, add some spacers and lift it
haha
haha
- WhiteFinish
Re: Front subframe
It's not an Xterra
jaydog is back
Re: Front subframe
Did you disconnect the steering shaft from the rack and pinion?
- WhiteFinish
Re: Front subframe
No no, that's what you do on a unibody R50 PathfinderWhiteFinish wrote:It's not an Xterra
And Subaru's
