I'm going to school this September for automotive mechanic.
I own a 94 gs. Engine seems to be in good shape with 175k on the body and engine and the clutch is dying. I seem to have an issue with my rear back tire as well, almost sound like something is hitting my tire or something.
Back to the point, I'm not sure if I should change the clutch and just leave it, or change the engine as well to the klze. From my understanding the change will cost roughly 1 grand, I'll be doing th labour (first time ever doing this). I'm jus tot sure if it's worth it for my car. It does have two huge rust holes and the body does have a decent amount of dinks in it.
What should I look over to help me better judge if it's worth it?
clutch is dying. new engine or what?
Re: clutch is dying. new engine or what?
Replacing the clutch is no big deal. The tire noise may be a bad strut. Your car has low mileage so if the engine is running well then put a a new clutch in and check if one of your rear struts is leaking.
- wednesdayslatest
check the rear upper mounts too you wouldnt want one of thos going on you (i already did from rust)
03 Dodge Neon (rental i had for a month but i ran that into the ground for sure)
95 Chrysler Concorde (Junked my first car [still ran])
90 Nissan Stanza (Junked [wouldnt start one day])
89 Saab 9000 CD (sedan/turbo very fun but electrical problems[city towed away for no plates on private property])
94 Toyota Camry (mothers old car fixed it then broke it[dont ask] Junked)
93 MX-3 RS (My project for 3 years so far)
97 Honda Civshit (Beater/Stereotypical POS Honda im fixing)
