What is this ?
WhiteFinish
What is this ?
Post by WhiteFinish »
What is this thing ?
It's located in the engine bay, both sides. Near the power steering fluid reservoir and near the fuse box.
Does it need to be bolted down for a ground or just hanging there ?
I want to move it a bit out of sight.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
lucifernl
Re: What is this ?
Post by lucifernl »
that are the grounding points.
greetings kevin
WhiteFinish
Re: What is this ?
For what electrical things are those the ground?
Worklog click
kulluminati777
Re: What is this ?
Post by kulluminati777 »
I always thought they grounded the headlights
mitmaks
Re: What is this ?
Post by mitmaks »
Dali
Re: What is this ?
Post by Dali »
I shifted some wiring around in the engine bay and mounted it on the other side in the wheel well, used the same bolt hole as well.
1993 White gs klze.
WhiteFinish
Re: What is this ?
Dali wrote:I shifted some wiring around in the engine bay and mounted it on the other side in the wheel well, used the same bolt hole as well.
Now thats a tip !
Worklog click
MazdaMech
Re: What is this ?
Post by MazdaMech »
So, you just bolted it in the same hole in the wheel well? Is that just to clean up the engine bay a bit?
Own:
2012 Chevrolet Camaro LS
2006 Chevrolet Uplander LS
1999 Ford F-250 XLT LD
1992 Mazda MX-3 GS (Rescue from a poor handler) *In work*(Body, interior, (future - KL swap))
1987 Dodge Dakota LE
1983 Honda CX-650C +parts bike
Looking at:
TRYING TO FIND A MX-3 Daily! No Luck:-(
