Guys, thank you for any help you can offer. I'm putting a ZE in it and if I can't go 40 then I certainly can't go 100
1 & 7 might be better, 12 & 6 is more likely to be play in the ball jointskulluminati777 wrote:did you shake the wheel back and forth at the 12 and 6 like i already said
true they dont have t+o be loose but that is a symptom for sure. The noise im sure he has is the bearing failing as mine did. mine stayed loud while i was going straight. When i took a sharp off ramp transferring the weight of the vehicle a tad the noise got quieter.crazycanadian wrote:Wheel bearings dont have to be loose to make noise . Wheel bearings get louder as you turn left or right. Transmisson bearings get louder depending on what gear you are in or on and off the gas. Intermediate shaft bearing is a constant noise that gets louder with road speed. Be carefull though. If your tires have anu cupping they can be noisy and sound like an intermediate shaft. Intermediate shafts are also normally pretty noisy if you are just spinning the wheels off the ground and listening to it with a stethoscope
No its not a symptom for a noisy bearing.. I have seen many wheel bearings loose but not noisy... On our cars design though a loose bearing still should be replaced...kulluminati777 wrote:true they dont have t+o be loose but that is a symptom for sure. The noise im sure he has is the bearing failing as mine did. mine stayed loud while i was going straight. When i took a sharp off ramp transferring the weight of the vehicle a tad the noise got quieter.crazycanadian wrote:Wheel bearings dont have to be loose to make noise . Wheel bearings get louder as you turn left or right. Transmisson bearings get louder depending on what gear you are in or on and off the gas. Intermediate shaft bearing is a constant noise that gets louder with road speed. Be carefull though. If your tires have anu cupping they can be noisy and sound like an intermediate shaft. Intermediate shafts are also normally pretty noisy if you are just spinning the wheels off the ground and listening to it with a stethoscope
