hey guys.
i got a msd 6al cheap and wanted to install it with a blaster 2 coil or ss, but i got confused about the wiring.
would it work like this? (it's a ze in a '92 mx)
MSD HEI mod with external coil
Black Mx3 GS
ZE swapped with kl36 ecu and Exedy oem clutch, Fidanza flywheel, 2.5" stainless exhaust, Ebay headers, 8mm sparkplug wires and Denso iridium sparkplugs, Rockspeed CAI, 17x8 wheels, 235/40 Goodyear eagle f1 as, Taroc japan sport discs and pads.
- mazda915
Re: MSD HEI mod with external coil
dam looks confusing . I know me and my friend tried on his mx but he had a ems on it and we could not get it to start lol so we wired it normal but u can always call msd .
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
i spend a couple of hours searching and found a nice diagram for msd with external coil on mazda k series.
i also discovered that they have made a harness for k series with internal coil.
Black Mx3 GS
Not sure why you would need to spend hours searching when it's all in our FAQ section.
viewtopic.php?f=23&t=69006
viewtopic.php?f=23&t=53706
or even here. http://www.clubprotege.com/wil/howto/hei/
Gro was the first to post this as far as I know so kudos to him.
i've seen those diagrams a tons of times, but i dont want to be using a gm module to trigger my msd 6al. so i found another diagram using an TIP3055 npn transistor.
Black Mx3 GS
Would you mind sharing why you no want to use the GM module. Gm module is very dependable.
Do what you wish, but the GM HEI is a cheap and dependable module and mod and provides a cheaper alternative than to replace the factory one, and making it much easier to service. That module is able to drive a V12
I'm running GM V8 ignition coils in my Rx8. Not one company makes everything 100% perfect, so sometimes we need to source alternative and better parts through other makes.
i dont have anything against the GM module, but the TIP3055 makes me able to make a much cleaner looking set of wires
and here in denmark, the cops send you to inspection if theres anything that looks out of normal
Black Mx3 GS
