DE swap - Starting issues
MX-3zoom
Post by MX-3zoom »
De motor swap.
Using old K8 parts.
I am getting fuel, spark, and air! When I go to start the car, it will crank fairly strong. Then it starts dying off slowly (crank-crank-crank-stall-pop-crank---crank---crank). I got piston one set to top dead center on combustion side. Tweaked with the disty while trying to turn it over. Nothing... So now flames and pops come out of the exhaust (they use to shoot out the intake). I've noticed j the negative battery cable gets hot while cranking. Help! Tips!
PLEEEAAAASSSEEEE!!
___________________
Black '92 GS [Project De-t Started!] [The spoiled one] :twisted:
Green '95 1.6 [Daily][The jealous one...SOLD]
White '07 Mazda 3 GT [The pretty one]
[What can you say, I have a fetish for 3's]
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
BornSticky
Re: DE swap - Starting issues
Post by BornSticky »
check you spark plug wires are in the right order and if its not that it might be the timing is out a couple teeth
#5389 to join MX-3.com
MX-3zoom
Post by MX-3zoom »
Thank you so much for the info! I will check them out. I'm new to the whole timig thing, I have so friends helping. So hopefully they know how to properly time it.
thanks again!
___________________
WhiteFinish
Post by WhiteFinish »
Are intake and exhaust cams in the right way ?
Also alligned ?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
MX-3zoom
Post by MX-3zoom »
Thank you bornsticky! Plug wires didn't match up with the disty. Now! It fully turns over! But it runs for two seconds, then dies unless throttled hardcore. I've noticed a massive air sucking sound. My friend removed the oil cooler lines from the front and rear valve covers, and put mini air filters in its place. Could that be what's it? I know the front runs to the side of the motor- over the transmission - intersecting with the line that's runs to the intake- then to the rear cover.
___________________
mx3_ryder
Post by mx3_ryder »
Where is the air sucking sound coming from? Are you running an oil cooler because i think those lines are your pcv lines and need to be hooked up properly. Also make sure your oil cap is tight.
MX-3zoom
Post by MX-3zoom »
From the PVC pipe. They were removed and capped with filters. The line that runs off the front valve cover sucks massive air. So I guess I answered myself lol. Its going to be a pain installing it since the intake manifold is almost up to the firewall. Could that really be the issue? What other vital lines?
___________________
Sleeper6
Post by Sleeper6 »
MX-3zoom wrote:From the PVC pipe. They were removed and capped with filters. The line that runs off the front valve cover sucks massive air. So I guess I answered myself lol. Its going to be a pain installing it since the intake manifold is almost up to the firewall. Could that really be the issue? What other vital lines?
yea these motors dont like vacuum leaks, my old k8 would die out just pulling the oil dipstick. tap those into your intake and your set
MX-3zoom
Post by MX-3zoom »
I will give it a try in the morning !
I will also check for other leaks.
Thanks everyone, I will post results!
___________________
Thefez
Post by Thefez »
sounds like you have major vac leak problems use a can of carb cleaner to help you find them. get that PCV system hooked up or youll destroy your engine.
MX-3zoom
Post by MX-3zoom »
I've got it sat up now...
I removed the intake manifold....bam... Coolant chilling between both heads. From the fat coolant pipe between the heads, guessing the o-ring is out. Has a four second drip.
Yay yay... Another minor set back, but I'm thankful for the forum and your guys help. I would of taken my friends word... And had to start over! Grr
___________________
MX-3zoom
Post by MX-3zoom »
Also, with the egr system removed. Will that cause a significant difference in trying to start it? With low 60 degree weather?
___________________
MX-3zoom wrote:Also, with the egr system removed. Will that cause a significant difference in trying to start it? With low 60 degree weather?
No it won't. I'd suggest a block heater though. lol Go over your engine and check for vac leaks. Feel and listen.
WhiteFinish
You can also use some breakcleaner, just spray it on and see if the idle changes / bubbels.
Worklog click
MX-3zoom
Post by MX-3zoom »
Will do. It'll be a few before I get it turned over. Quick fix on the coolant line. Definitely will do brake cleaner tip!
:D
___________________
