WTB: Outlaw Engineering pheno spacer for throttlebody
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
Jforce
Post by Jforce »
I'm looking for the throttlebody spacer + throttlebody hardwarde ONLY.
Its only meant as an adapter for klg4 + throttlebody.
Anyone who can help me on this?
This type:
MrMazda92
Re: WTB: Outlaw Engineering pheno spacer for throttlebody
Post by MrMazda92 »
Good luck... Try ordering it through their site...
I only ever found ONE used TB spacer... I bought it, and the package tore mid-transit, the spacer is lost forever. :cry:
Jforce
Post by Jforce »
Yeah, i contacted outlaw. Seems they only sell the whole kit :/
Maybe it's easier to make or let someone make an alu adapter plate?
Dont feel like grinding the throttlebody down as i may want to swap to long neck or curved neck again later.
MrMazda92
Post by MrMazda92 »
Wait, why would you ground the TB down?
You could take the factory aluminum spacer and have it ported to match your TB opening... You really don't need to though, people run K8/KLs without the spacer all the time.
kulluminati777
Post by kulluminati777 »
:lol: :lol:
Just buy the entire kit from outlaw. You wont be disappointed in the upgrade :mrgreen:
Take a gasket to a shop with a water jet and have them make you one from some phenolic. Not a big deal.
Jforce
Post by Jforce »
@ MrMazda92, here's why:
@Daninski, Cant find phenolic here. Dont know what it is called in Dutch, and i will need the lenghted bolts as well.
@kulluminati777, I heard outlaw's spacers can cause a cracked manifold. KLG4 are very rare on this side of the ocean, so i don't want to risk that.
kulluminati777
How would it crack your manifold??
I have had mine on for three years with no issues and a cool intake manifold 8)
MrMazda92
Post by MrMazda92 »
Ahh, you could grind the nub down on the TB or the space it would otherwise occupy on the manifold, was that picture from xtremethings.com?
The spacers shouldn't have any negative effect on your intake manifold, but you might need longer bolts to install them. IIRC, you can use the stock bolts, but you would only have a few mm of thread bite if you did so.
Try having your stock K8 throttlebody spacer bored out to 60+mm, and go from there!
Jforce
Post by Jforce »
well, I got one.
A used intact throttlebody spacer with bolts.
Return to “MX-3 Related Want to Buy Forum”
