wertys, thank you for the compliment! Some of those took me a lot longer to get ahold of than others...
The injectors will honestly do next to nothing for you unless you are planning to turbo or supercharge your car. The benefit that most see and use is an increased capacity to deliver fuel, without the odd spray patterns that occur when you overpressurize your stock injectors beyond a reasonable point.
Basically, if you plan to run more than 3-4 pounds of boost(this is information from the forums, I haven't personally verified the same limit for stock injectors), then you should upgrade to a higher flow injector. These are from a supercharged Millenia, and drop directly into KL fuel rails with zero modification.
kulluminati, there is a Stratified ECU for sale used, on MX6.com right now. Unless somebody snatched it up already...
Mine will definitely be used, hopefully this month, if all goes to plan!
The picture was already in my imageshack folder, I didn't feel like arranging the injectors all sexy like and snapping a new photo. Besides, the other shiny items distract people and make them more likely to send me moneys.
I know it's lowball offer but if you're willing to part them for 50$ shippied, consider them sold! Just sell them to me if you're really desperate to have money lol
thanks again.
