sinix3's 92 gs kl swap
sinix3
Post by sinix3 »
been around for a few months and have been wanting to start a work log but havent had the time well here it is im going to start one.
i bought a 92 mx3 gs about a year ago and after rebuilding the top end it was great until i heard about a klze swap. so i found a mx6 and was planning to do a klde swap and turbo it but the car turned out to have a klze swapped into it. my first task was rebuiolding the engine which i have done. not entirley sure how to post picture but i will try and i will continue to update the log in the future
92 mx3 gs klze swap.
"nitrous is like a hot chick with an std you know you want to hit it but your afraid of the consequences"
RobMinhas
Re: my kl swap
Post by RobMinhas »
Whereabouts in BC are you? I'm from BC, a little town called Radium Hot Springs, just going to school in Calgary.
I don't know about anyone else but the pictures don't work for me.
MrMazda92
Re: my kl swap
Post by MrMazda92 »
I'm glad to see you started a worklog!
I hate to be the pest, but you do need to change the title a bit to adhere to forum rules... The format most accepted would be "sinix3's _____", where ____ could be replaced with 92 MX3, 92 GS, anything along those lines :)
That will mostly make it easier for people to tell who's car it is, without having to peak over at the thread author space. It's not one of the strictly governed rules, but it really does keep the worklogs a little tidier.
I can't wait to see the pictures, keep us up to date will ya? :)
kulluminati777
Re: my kl swap
Post by kulluminati777 »
You might want to fix the title brozinski
EDIT I just seen mrmazda told you lol sorry
Dali
Re: my kl swap
Post by Dali »
I'm in Williams Lake BC if you need a hand (if you know where that is) Good luck.
1993 White gs klze.
sinix3
Re: my kl swap
Post by sinix3 »
i live in mission. and i got the swap done in 2 days haha proud of myself on that part. but it has an intermitant miss a weird idle some times and its running rich but i still have to swap the computers. i will cange the title. thank you for the imput
Re: sinix3's 92 gs kl swap
So did you change important items like fuel filter, hoses and belts. I found it very easy with the engine out but very difficult when it's installed.
sinix3
Post by sinix3 »
I changed needed hoses but forgot about the fuel filter. And yeah I change the belts aswell
crazycanadian
Post by crazycanadian »
Nice bud... Will have to get together some day.. Hopefully meet up at the track this summer... I am just out in Cloverdale..
sinix3
Post by sinix3 »
swap is all done and on the road. i swapped my ecu anf vaf for the one out of my donor car. now my idle is all goofy so i think i have to set my tps. again im going to try and post pictures soon just have to figure out how:P if any one has any sudjestions on my idle issue. any imput is greatly appreciated
