Since we have the WORST search feature ever. I couldnt find the actual removal....
I removed the two screws on the right and left of the mx3 then took off the interior plastic pieces inside the trunk and removed 4 (2 bolts right next to each other on each side of the car) Is there any thing else to remove?? This thins is NOT budging....
Rear bumper removal
- kulluminati777
- MrMazda92
Re: Rear bumper removal
Yank the taillights, there are some bolts underneath them. Also CAREFULLY remove the panel beneath the hatch, and between the taillights.
- kulluminati777
The tail lights.....duh im such a loser thanks alot
- MrMazda92
No guarantees man, I haven't pulled it myself, but I do remember there being a great deal of crap concealed by those!
Good luck with it, post a guide maybe!
- mitmaks
JayoM
I had a bastard of a time getting unbolting the bumper from underneath. That was the toughest bit as far as I remember. There are a lot of bolts hidden around the place in that boot!
I didn't need to remove the bolts beneath the tail lights to get it off either!
