Page 1 of 2
suspention questions
Posted: December 12th, 2012, 5:11 pm
by sinix3
ok so i have a few questions.
my struts blew on my gs and the drivers front spring broke.
ever since i changed the struts all around(not brand new but not blown) i have had a strange steering
when i hit a bump my steering wheel turns and my car jerks to one side. my question is if anyone knows what could cause this and how to fix it. i am also wondering if there are any mods for our suspention that will make it stronger inorder to take corners tighter. any help is welcome.
Re: suspention questions
Posted: December 12th, 2012, 7:26 pm
by kulluminati777
more than likely your alignment is WAY off. Mine does that too but i know my alignment is off
and a full list of suspension mods;
SRD cross member
SRD rear tie bar
Mazdaspeed or corksport front strut bar
mazdaspeed or Corksport Rear strut bar
bpt323's Traction Bar on LCA´s
K-sport Coilovers
Whiteline or mazdaspeed Rear sway bar
mazdaspeed Front sway bar
ZX2 Tubular Trailing arms
Pierce motorsports tubular lateral links
C- Pillar bar
energy suspension poly urethane bushings to replace rubber ones all around
i have heard koni/ZX2 stuts with eibach springs or ground control sleeves are ok. Trust me just save up a few more bucks and get an ACTUAL coil over set up. Also any ebay un named stuff like strut bars and stuff your just wasting your hard earned cash so dont bother....
Posted: December 13th, 2012, 2:38 am
by MrMazda92
I'm running Ground Control sleeves(granted, mine aren't an off-the-shelf option), but honestly I like them quite a bit. If you go with a tender spring setup, you can have a variable spring rate without sacrificing much.
I love it, although figuring out exactly where I wanted the ride height was a PAIN. To each his own...
Posted: December 13th, 2012, 10:45 am
by sinix3
Ok thank you. I will be checking my alignment today. And as for the suspention i have. No idea where i can buy any of these things haha
Posted: December 13th, 2012, 10:47 am
by crazycanadian
Where is BC are you from bud?
Posted: December 13th, 2012, 11:44 am
by DeadMaker
kulluminati777 wrote:more than likely your alignment is WAY off. Mine does that too but i know my alignment is off
SRD cross member
SRD rear tie bar
K-sport Coilovers
C- Pillar bar
Have you installed ZX2 Tubular Trailing arms?Do have them on now?Any pic?
Thanks..
Posted: December 13th, 2012, 1:12 pm
by kulluminati777
Ill take pictures when my car gets here. Its still on the boat from germany
Posted: December 13th, 2012, 2:58 pm
by kulluminati777
sinix3 wrote:Ok thank you. I will be checking my alignment today. And as for the suspention i have. No idea where i can buy any of these things haha
The ZX2 trailing arms you can get off a escort zx2 in a pick and pull
The SRD stuff you can get from another member or I believe blaznlow and nd4spd are selling relicas that are FANTASTIC
The coilovers you can get em from ebay
The energy suspension bushings just ask mx3matt where he got his
corksport bars from corksport.com
the mazdaspeed bars good luck
the lateral links you would have to make your own endlinks if you get them but its not hard
http://www.piercemotorsport.com/servlet/StoreFront
C-pillar bar I dont know
Whiteline sway bar from ebay or there website
Posted: December 14th, 2012, 12:21 am
by sinix3
I live an hour from Vancouver. Like if there was a store i would save money (as i am a collage student working part time and building a car) and then go buy them but as far as i m now there's no stores that sell performance parts for our cars
Posted: December 14th, 2012, 12:26 am
by kulluminati777
nope none at all....
your best friend is the internet and the WTB section here on this web page.....
Posted: December 14th, 2012, 12:29 am
by sinix3
Yeah it's just hard to find people in my area haha. Really all i need to find is suspention stuff. Te rest i can mod to fit or just plain make. But thank every one for the list of things and a general way to acquire the parts
Posted: December 14th, 2012, 3:35 pm
by sinix3
does anyone know if a mx6 steering rack would fit a gs?
Posted: December 14th, 2012, 4:08 pm
by wytbishop
part numbers do not cross. It's similar, but likely different enough to cause a problem. Even if it does fit, it will have a different ratio and stuff.
Posted: December 14th, 2012, 5:56 pm
by sinix3
Damn
Posted: December 14th, 2012, 7:54 pm
by MrMazda92
323 manual rack will work...
I know that Probe guys sometimes use the 323 manual rack, so maybe there's a crossover there?
